Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 10-17-2007, 10:24 AM
Steve A's Avatar
Steve A Steve A is offline
Default Dan Lloyd/Eggenfellner First RV-10 Alt to Fly?
A few months ago, T Sweezy was asked if he was going to the first RV 10 with an alternate engine (not an Lycoming or clone). I am assuming that the Subaru Turbo owned by Dan Lloyd has captured that distinction.
However there may be someone somewhere with a Allison V 12 in there RV 10 so I thought I would throw this out.
Old 10-17-2007, 11:42 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
But---------the Allison is an aircraft engine, so it really isnt an alt engine.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-17-2007, 01:46 PM
Steve A's Avatar
Default Allison V 12 Engine
Again my memory is shakey on this but wasn't the Allison a copy of the Packard 12 used first in auto's. WWII came along and an engine was needed proto to put into the Mustang. The Mustang was originally commissioned by the British before the US entered the war. They needed something good, fast and over there fast. And what a wonderful airplane, even more amazing is the design was done in record time.
If I am incorrect on the origin of the Allison, I stand corrected. It would be the first time I was corrected on this forum, or is it the fortieth time, I forget.
Old 10-17-2007, 03:03 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The Allison V12 was developed in the early 1930s so it was fairly mature by the time it was fitted into the P51. The engine came well before the airframe.
Allison was acquired by GM around the same time.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 10-17-2007, 03:11 PM
Rotary10-RV Rotary10-RV is offline
Default Packard built the Merlin
Packard Built the Merlin under wartime license. They were excellent engines too, as the "Packard Merlin" was a favorite among the pilots. I believe they built some Pratts too. They really didn't fare well when converting back after the war. They shortly failed. Too bad as they built fine cars.
Bill
