Old 10-14-2007, 02:23 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Default Riveting Rudder Nutplates
I'm getting ready to rivet the rudder spar and nutplates together. I can't find any notes on the plans about what rivets to use on the nuts themselves. Could anyone point me in the right direction? Also, do the shop heads go on the inside, or the outside?
Thanks!
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 10-14-2007, 03:14 PM
Rivethead Rivethead is offline
When in doubt 1.5 diameters for the shop head. It's direction is your choice but the shop head would probably be better against the nut plate.
Old 10-14-2007, 07:49 PM
rivetshaver rivetshaver is offline
Look at dwg #7, the side view of the rudder has the fastener callouts at the uppermost and bottom rod end bearing detail. I don' remember if these were correct, use the 1.5 D rule if needed. The plans do have fastener callout errors.
Gregory Targonski
Peachtree City GA
RV-9A Flying as of September 12, 2013
Old 10-15-2007, 12:34 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Sometimes ya gotta hunt down those callouts!
I don't think I have failed to eventually find them, but you may have go looking through several sheets of plans, as you will find out with the wing kit for some of the brackets.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
