Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
06-21-2022, 12:44 PM
Does Proseal Chemseal B2 TANK SEALENT STICK TO PLASTIC
EDIT: High-density polyethylene (HDPE) *tank materal*
I did try "plastic welding" using a solder iron. It worked mostly worked, looked good, but it seeps. Pin hole? Was not aggressive enough. This is where sealant comes in. I am going to try again.
As any builder knows proseal or tank sealant sticks to everything.
Will is work on plastic fuel tank? The sealant is primarily for metal, however if the plastic is clean, roughed up, it should stick?
ANY EXPERT OPINION (or wild guessing) Appreciated.
George
Raleigh, NC Area
2023 Donation Made!
06-21-2022, 01:04 PM
I installed my NACA plastic cockpit vents with proseal. Inside of aluminum skin was already primed and painted. I roughed up the mating surface of the vents with sandpaper prior to mounting. Not flying yet, but they seem to be permanently installed.
Terry Edwards
RV-9A (Fuselage)
2022/2023 VAF Contribution Sent
06-21-2022, 01:36 PM
Depending on the plastic, a primer may be required.
Dan Morris
Frederick, MD
PA28-140 sold
Hph 304CZ sold
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
06-21-2022, 02:26 PM
I used it many years ago to add vents to these new ventless “green friendly” plastic fuel cans that have those silly push down to open spouts that spill fuel everywhere but in the tank. I drilled out some brass and rubber tire valves, drilled mounting holes for them, then pro sealed them in. Replaced the spouts with old fashioned replacements you can still buy. Holding strong many years later and no longer have to fuss with non venting cans when I use them.
David C.
Howell, MI
RV-10: #41686 Under Construction/Sold 2021
"Donor Exempt" but donated through Dec. 2023
06-21-2022, 03:09 PM
What specific material?
Some non-metallics would require flame passivation to allow a bond, then yes.
EDIT: Flame passivation is especially applicable to HDPE.
Bill
RV-7
06-21-2022, 03:50 PM
Proseal/plastic
YES Short answer
I have a 2001 RV-6A the other guy built.. He put the cowl pins in from the inside the cabin through the NACA vent. Bad idea
My NACA vents were both broken beyond repair, because of this failed trick. I used a heat gun to warm the Proseal and peeled them off with a putty knife. Glued new in place with more Proseal. 25 year old stuff to boot. no special prep either.
Never let go in 20 years. New ones are a year or so old. White airplane, so painted the vents black after installation.
Your luck may vary Art
Fixit
06-21-2022, 07:18 PM
I repaired a plastic hydraulic oil tank on my boat about 22 years ago and still no leaking. No idea the type of plastic though.
06-21-2022, 07:43 PM
Proseal
I have a can of Vans FlameMaster about 8 years old. I always mix a test before use. I fixed a leak on my Thermorest Mattress. Sealed the gaps on the Frankensnorkel. Many more odd jobs. It definately won't stick to a slick surface so abrade the plastic with 80 grit first.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
06-21-2022, 07:54 PM
EDIT: High-density polyethylene (HDPE) *tank materal*''
Of course it has to be fuel proof.
George
Raleigh, NC Area
2023 Donation Made!
06-21-2022, 08:22 PM
I don't believe it would stick much to HDPE. Getting adhesives to stick to HDPE is very difficult.
Alex Peterson
RV6A N66AP 1800+ hours
KADC, Wadena, MN
Thread Tools |
Display Modes |
