Old 11-12-2021, 10:44 AM
rvbuilder2002's Avatar
Originally Posted by 00Dan View Post
Donít the current Vanís cowls also require an extension? I know my old fixed pitched Vanís cowl on my -4 requires a 4Ē extension, and I think the CS cowl required a 2.25Ē extension.
The standard kit supplied cowls are designed for use with the Hartzell compact hub propellers.
When a fixed pitch propeller is used instead, a 2.25" extension (actually spacer) is required.
Prior to developing a cowl designed for use with the Hartzell compact hub prop., the cowls required a 4" spacer be used with a fixed pitch prop, or the use of the extended hub version (approx. 1.75" longer than the compact hub) of the Hartzell propeller.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 06-06-2022, 07:42 PM
AlphaCharlieBravo AlphaCharlieBravo is offline
Default Saber Manufacturing
Just received my 4" Saber Prop Extension for my extended James Cowl and Lycoming A1A engine and it is a work of art. Beautiful!
Going with a three blade Catto prop. Spoke to Nicole the other day and getting that order in this week.
Arnie
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
