Old 05-16-2022, 09:12 PM
N29945 N29945 is offline
Default ADS B out question
I have an RV6A with a Garmin GTX327 Transponder that seems to work well however it is 20 years old, what are my best options for ADS B out, my avionics guy is not really sold on the tail beacon option.
Jim Skinner exempt but gladly contribute to the expenses of this organization, it is one of the best investments I make once a year.
It helps me make informed decisions
Old 05-16-2022, 09:54 PM
Robin8er Robin8er is offline
What's the opposition to the tail beacon? As long as you don't plan to fly outside the US it works fine. I have the nav light version on my wingtip and haven't had any problems, I know plenty of people that have them and haven't heard any complaints.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 05-16-2022, 10:07 PM
OKAV8r OKAV8r is offline
Default Best bang for the Buck
The GTX-327 transponder is a good unit. I suggest you keep it and install a GDL-82 ADS-B out. That's a pretty bullet proof combination. If you shop around, a new GDL-82 unit can be had for less than $1700. Install is not bad, just takes some time.
Second would be the Echo UAT with SkyFyx (uAvionics). The best way to install with the GTX-327 is the additional MUX cable, so it would be a bit more than the GDL-82 all-in, but the Echo/ SkyFyx includes ADS-B IN.
Old 05-17-2022, 05:34 AM
BH1166 BH1166 is offline
I just installed a GTX327 NEW unit. Had a King 76A with EchoUAT/ GRT SafeFly gps…..works well.
Butch
RV6A Purchased N72TX
Old 05-17-2022, 06:20 AM
Super Moderator
The 327 is a great unit. If you want some extra "IN" functions, like weather and traffic, consider the Echo Uat. It has WIFI out and you can also hardwire it to an EFIS.
We've done lots of setups like these in the RV's.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
Old 05-17-2022, 09:42 AM
rolivi's Avatar
rolivi rolivi is offline
I have the GTX327 and tailbeacon combo. Works great, and it was an easy install.
I request PAPRs after most of my flights and have never seen any RED on them, so I know they're doing their jobs.
Rob
RV-6A (Purchased)
2022 Dues Paid
