Old 05-12-2022, 06:31 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by Prepperpilot View Post
Tailwheel chain clip busted loose. Strong crosswinds.
The bent wire kind? They can be safety wired. Or given a flotation test and replaced with:
https://www.lowes.com/pd/National-Ha...eel/1002234754
Name:	Tailwheel Cable.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-12-2022, 12:00 PM
Prepperpilot's Avatar
Prepperpilot Prepperpilot is offline
Yup. Will probably go the shackle method on next annual.
Makes we wonder why use clips at all.
New RV-8 Owner - N717SR
Based in Ohio - 9OA5
Former T-38 FAIP
Global Express (Work Airplane)
Slowly getting back into GA Flying!!
Old 05-12-2022, 12:22 PM
RV6_flyer's Avatar
Looks like what I have been doing except I have a Clevis at the front also. This would be a lower cost option and less than an ounce more weight.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-12-2022, 01:25 PM
ljsflash's Avatar
ljsflash ljsflash is offline
Dan, I can find one of these anywhere that fits the factory hole. Did you enlarge the hole or is there a small diameter pin option?
LJ Smith
Annapolis,MD
RV-8 Bought, Flying
DR-109 Built by Doug Dodge and Dan Rihn- Flying
Super Decathlon- Sold
Old 05-13-2022, 07:07 AM
Tomcat RV4 Tomcat RV4 is offline
Home depot and Harbor Freight have various sizes.
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 05-13-2022, 07:32 AM
HFS HFS is offline
Default Cable Shackle For Rudder Horn
Here are the specs for different cable shackles (from Genuine AC Hdwe).
We typically use AN115-21, which already has a .188" hole diameter. If that's not large enough for you (even though the plans call out is for a -3 bolt), there is ample edge distance on the hole flange to enlarge it a bit for your needs.
YMMV
HFS
Name:	Cable Shackle Specs..jpg
Old 05-13-2022, 07:38 AM
ljsflash's Avatar
Default Thanks!
Thank you HFS!
LJ Smith
Annapolis,MD
RV-8 Bought, Flying
Old 05-13-2022, 08:02 AM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Default Jack
In addition to some of the above tools, RV8 travel jack in case of that unexpected flat tire.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Build Log
Old 05-13-2022, 09:30 AM
DanH's Avatar
An eyebolt with a few spacing washers at the rudder horn drops the cable assembly below the bottom rudder cap at full deflection. Might not need that on a -6, but it's needed on the -8 when the attach point is moved inboard to correct the rudder/tailwheel ratio.
You bet! A fella can usually borrow tools, but jacking Grove gear out in the boonies might be tough. I carry two of these, left and right. They pick up two axle attach bolts and allow the use of a small jack, or even a log and a limb for a lever. Note the modified wrench to reach in behind the disk and hold the bolt head. Wouldn't be needed if I got off my lazy butt and installed some sort of head lock.
ID:	25775  Click image for larger version
ID:	25776  Click image for larger version
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-13-2022, 12:33 PM
pjc's Avatar
pjc pjc is offline
As usual, much learning here for me.
Dan, can you elaborate on finding/setting the “correct rudder/tailwheel ratio”. I have been curious about this ratio’s effect on ground handling for some time. I have a 6 with stock old-school Van’s fully swiveling tailwheel if it matters…
Peter
Vans RV6 flying
SZD 48-2 sold
2018, 19, 20 Dues paid
