Go Back   VAF Forums > Education > Flight Testing
  #21
Old 05-14-2021, 11:46 AM
kaa kaa is offline
By the way since Mel is in the topic, if someone decided to do this (I don't recommend), how would it play with FAA rules?
Konstantin Azarov
RV-7
Old 05-14-2021, 01:26 PM
Mel's Avatar
Mel Mel is offline
There are no limitations by the FAA for such testing that I'm aware of.
However, PRUDENCE should be a very high priority here.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-14-2021, 02:18 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I'd probably want a more positive means of securing the disconnected flap than just speed tape. Could also reprogram the stops on the remaining flap so that it can't deploy past a certain angle (adding a physical stop would be even better).
It would be simple to safety wire the flap to structure inside the RV-8 once you removed the linkage. And the standard flap actuation system doesn't have “stops” - its just analog as long as you hold the switch. If you have an aftermarket system that goes all the way to a preset position with each switch toggle, and it couldn’t be defeated, I wouldn’t even attempt this test.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-14-2021, 03:42 PM
kaa kaa is offline
I have Garmin and it can be programmed so that it only goes to say 10 degrees and doesn't go past that, that's what I meant.
Although if any electrical system decides to get stuck and lower flaps all the way down during this, it's not going to be good news.
Konstantin Azarov
RV-7
Old 05-14-2021, 03:55 PM
Ironflight's Avatar
You see - now you’re thinking like a flight test safety analyst! That’s what anyone should be doing for any test they plan to do with specific equipment included.
BTW - the operational control for a “flap switch stuck down” in most ordinary configurations is to pull the breaker, so you’d flag that breaker in advance. It’s all in the planning.....
Paul F. Dye
