Old 03-07-2021, 10:48 PM
rvbuilder2002's Avatar
Maybe it won’t be the case with yours but I think you might find that with nuts positioned aft, the bolts will interfere with the rudder.
Scott McDaniels
Hubbard, Oregon
Old 03-08-2021, 08:00 AM
kentlik's Avatar
kentlik kentlik is offline
Thank you, Scott! I am sure they will interfere...haha. I pulled it off shortly after this photo to finish the F-781 Vert. Stab. plate so I will reverse those bolts at your recommendation! Thank you again! Any helpful hints like this in advance are appreciated.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-11-2021, 06:29 PM
kentlik's Avatar
Default Tube, elevator
I got to put in my elevator tube for the first time! So exciting.
[IMG]tube by Kent Luttrell, on Flickr[/IMG]
Checking rudder to VS spacing
[IMG]rudder by Kent Luttrell, on Flickr[/IMG]
Didn't get much done today, have a big work thing on Monday to prep for.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-15-2021, 12:53 PM
kentlik's Avatar
You were correct Scott, flipped those bolts around, and no clearance issues.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-15-2021, 05:29 PM
kentlik's Avatar
Default EMP fairing
Just started on the emp. fairing seems pretty decent really. A bit of sanding here a little floxy there and see what happens.
[IMG]fairing by Kent Luttrell, on Flickr[/IMG]
[IMG]fairing2 by Kent Luttrell, on Flickr[/IMG]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-15-2021, 05:50 PM
jcarne's Avatar
jcarne jcarne is offline
Dude you are killing it lately, keep it up!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 03-16-2021, 09:54 AM
kentlik's Avatar
Thanks, Jereme!
I am trying to get as much done before my next job starts. Not sure when that is currently but it will come.
You were very much an inspiration.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-16-2021, 10:08 PM
Blain's Avatar
Blain Blain is offline
Steady progress. Good job, Kent.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2021(my reminder)
Old 03-17-2021, 08:50 AM
kentlik's Avatar
Thank you, Blain! I have work that gets in the way from time to time but soldiering on! Starting to see it come together!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-01-2021, 02:28 PM
kentlik's Avatar
Default Tips
Found time to put these up
[IMG]20210407_174155 by Kent Luttrell, on Flickr[/IMG]
[IMG]20210407_174205 by Kent Luttrell, on Flickr[/IMG]
[IMG]20210416_120515 by Kent Luttrell, on Flickr[/IMG]
Not perfect but good to go for me
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
