Old 01-22-2021, 11:00 AM
Jab Jab is offline
Default Inconel welder
Hi all
I am in the Knoxville area, where finding someone who can weld an exhaust is difficult, so I am looking farther afield. Is there anyone in the Atlanta/Falcon Field area that could make two welds on an exhaust for me? I have to change the angle of the exhaust to clear the airframe, so a 4 degree angle change is needed, I can make the cut to get the angle correct. Should be two simple welds to join the pieces again. If anyone knows of a welder, please let me know.
Gary
Bought RV-4
KRKW
Old 01-22-2021, 11:28 AM
dpansier's Avatar
dpansier dpansier is online now
Contact Jody, he is in the ATL area.
https://www.weldingtipsandtricks.com/Jody.html
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 01-22-2021, 12:40 PM
ty1295 ty1295 is offline
If you can't find someone close, we can make it happen in Louisville, Ky area.
Jeff Scott
RV9A First Flight 9/30/19
Old 01-22-2021, 06:29 PM
terrye terrye is offline
The most common exhaust material is 321 stainless steel. Inconel is used for much higher temps.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 01-23-2021, 07:31 AM
Jab Jab is offline
Thank you for the suggestions, I will be in contact.
Bought RV-4
KRKW
