10-07-2020, 10:30 AM
Trim Tab Sheetmetal Thickness?
When I got my plane back from paint, looks as if the painter didn't put the trim tab back on. So.... I need to make one.
I didn't make my plane so I am not certain as the thickness of material I should use. I have some 0.32 material laying around. Is this acceptable or needs to be thicker?
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
10-07-2020, 10:31 AM
That will work
David "Stogie" Otero
Albuquerque, New Mexico KAEG
Owner:BladeSox, LLC . www.BladeSox.com
Member of Chile Flight
EAA Tech Councilor
Finished RV-7 12/30/15
N505RV
Segundo Viento
Paid my 2020 dues, you should too.
10-07-2020, 06:21 PM
Older kits (RV-4, -6) used 0.016 material (cut from the elevator skin). My new -4 tail kit use 0.020 for these skins, so the trim tab is also thicker.
10-07-2020, 07:54 PM
Listen to Dean. The trim tab is a bad place to add mass.
Dan Horton
RV-8 SS
Barrett IO-390
10-07-2020, 08:01 PM
Which tab?
Is this the elevator trim tab? Or is there maybe a trim tab on the rudder that is a bent piece of metal?
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
10-07-2020, 08:04 PM
Vans sells the trim tab skin for like $19 bucks! Throw in the hinge, spar, and control horn.. all pre bent. I think the cost of these parts is cheap compared to the time to fabricate them from stock. I’m sure it’s doable, just not sure it’s worth the time.
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
10-08-2020, 04:10 AM
That is an excellent point. My comment assumed the OP was asking about the elevator trim tab. (I'm building new elevators with 0.020 skins so everything looks like an elevator to me.) If the question was in reference to the rudder trim tab (which makes more sense given that the painter did not put it back on  ), the 0.032 thickness is good.
10-08-2020, 08:58 AM
If it should be the elevator tab, you can buy a kit for just that from Van's.
Dave
10-08-2020, 10:00 AM
VAF Moderator / Line Boy
Guys - read the original post - I seriously doubt that a paint shop would “forget” to put the [elevator] trim tab back on - I’d think it would be rather obvious it was missing.
I assumed he was talking about a rudder tab, and if that is the case, he might think of a wedge instead of a tab.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
10-08-2020, 10:17 AM
the AILERON trim tab was missing. It was kinda funny because when I noticed it, I looked for the tab and 2 of the 4 holes were pop riveted but no tab. Definitely left me scratching/shaking my head. Definitely left me disappointed with the work.
