Old 10-02-2020, 04:55 PM
Phugoid Phugoid is offline
Default A&Ps in the Tampa Area?
I need to replace the rudder pedals in my RV6 that broke this week. I ordered a new set from Vans.
I am not a mechanic, nor did I build my airplane. While I think I can figure out how to make the repairs (I stayed in a Holiday Inn Express once ), this goes beyond preventative maintenance. I need an A&P to oversee/inspect and sign off the repairs.
Are there any A&Ps in the Tampa area that might help me out? I just brought the airplane down from TN about a month ago, but I didn't bring my AMT with me!
Mark E
RV6 S/N 21299
I didn't build it, but I love flyin' it!
Land O' Lakes, FL
Airport: X39 (Tampa North AirPark)
Old 10-02-2020, 05:26 PM
Apparently you don't quite understand what you bought.
As an Experimental-Amateur-Built airplane, you are free to work on it to your heart's content, no A&P oversight necessary, with the sole exception of the annual condition inspection. Now, it certainly is a good idea to get some help, if you are uncertain of what you're doing. But it is not required.
Old 10-03-2020, 06:51 AM
swordtail swordtail is offline
This guy will fix it! Jesse Saint 352-427-0285. He is located at X35 Marion County. That is close to you.
Old 10-03-2020, 07:03 AM
You are right. I’ve been under the impression that I could not do my own maintenance because I am not the builder. After a little research, I discovered I’m wrong. I can do my own maintenance.
That said, I still think I wanna have an A&P at least check my work!
Thanks.
Mark E
RV6 S/N 21299
Land O' Lakes, FL
Old 10-03-2020, 01:19 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default I would probably go with Jesse to check my RV work!
He and his crew have probably seen it all!
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 10-04-2020, 04:43 AM
carlrai's Avatar
carlrai carlrai is offline
Thanks.
You have A & P service available on your field as well as another A&P/pilot based at Tampa North, Carlos Urbizu. (Flys a Mooney) I think he's in the first row of hangars, closest to I-75.
While Jesse is probably the best A&P for RV's in the state, why travel?
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
