Old 09-29-2020, 09:33 PM
Kevincav Kevincav is offline
Default RV-9A Average Oil Consumption
Apologies if this has been asked, I tried looking for it. I did a pre-buy for a beautiful RV-9A and most things seemed good. There has been concern about the oil consumption. It seems that it goes through a quart every 7-10 hours. Is this normal? I've talked to some people who were thrown off by it being so low. Obviously the seller / broker seem to think it's good. The engine has 740 hours on it with a new cylinder 4 years ago. This is an IO-320. This is the plane.
Old 09-29-2020, 10:20 PM
pjoshyjosh pjoshyjosh is offline
My 9A will use up oil until about 5.25 quarts. Then it slows way down on consumption. So, when filling, I try to fill to about 5.5. I can run 10-15 hours on .25-.5 quarts.
That's anecdotal at best..
But if you were in a similar -320 engine and filled to 6 quarts - it would consume faster for sure.
Joshua Muri
N8306R - PA28-140 Sold 11/2019
N72NJ - RV9A Purchased 10/2017
No N# - RV9/A Kit in progress
Empennage complete. Wing Kit on hand
Old 09-29-2020, 11:03 PM
bruceh's Avatar
bruceh bruceh is offline
I have an IO-320-E2D in my RV-9A. 820 hours as of now. I change the oil about every 35-45 hours, or every 4 months. Usually at around 30 hours I need to put in 1/2 quart to keep it at 6 quarts. I'm running Aeroshell W100 with Camguard. It doesn't really go through any oil. I send out my sample to Blackstone and they have basically said to keep doing what your are doing!
Bruce Hill
2020 VAF donator
Old 09-29-2020, 11:54 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
There seems to be a wide range of "normal" oil consumption in these engines. I'm no engine expert but from my pretty extensive investigations the consumption is a little high but still in the "good to go" range. But don't take my word for it -- the maximum oil consumption for the engine should be in the engine operation manual. If one of those isn't with the plane, it should be acquired and consulted.
It is a good idea to check for reasons why oil might be going where it shouldn't -- borescope the cylinders and look for pitting and check the condition of the valves, do a compression check, look for gunk out the tailpipe and on the belly, check for oil on the bottom plugs, and make sure there are no leaks. That will tell you if there is a specific problem.
Randall Henderson
RV-6 / O-360 / CS, 1500+ hrs, 1st flight Sept. 1999
Airport committee chairman & ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2020
Last edited by rv6n6r : 09-29-2020 at 11:59 PM. Reason: re-read the post, see it's a pre-buy so not the owner? Re-worded as such.
Old 09-30-2020, 02:24 AM
rvmv rvmv is offline
My IO320 with 200 hours is similar to bruceh’s. 1/2 quart ever 30-40 hrs.
Old 09-30-2020, 04:11 AM
Desert Rat Desert Rat is offline
rv6n6r has it right.
compressions good? Oil on the belly? What about the spark plugs? If the lower plugs were oily, it's possible it could be an oil burner even if it has good compression. About the best way to tell other than that is to borescope through the spark plug holes.
Personally, I would be annoyed by an engine burning that much oil, but Lycoming will tell you not to worry about it until it gets into more like a quart every 2-3 hours.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 09-30-2020, 05:41 AM
O-320 past two TBOs drinks one quart every 3.5 - 4 hours at 65% power
Old 09-30-2020, 06:48 AM
airguy's Avatar
airguy airguy is offline
Oil usage is all over the map - when I change oil and filter I put 7 quarts in, and my engine will dump most of 1/2 quart overboard within the first 2-3 hours. Then I'll need to add a quart at about 30 hours, and before I need to add another it's time for an oil change at 50 hours. I've got 750 hours on this engine and it has not been babied.
Old 09-30-2020, 08:22 AM
He suspected that it might have oil consumption problems but didn't see anything on it.
Old 09-30-2020, 08:35 AM
SMRacer SMRacer is offline
Default Preflight
Hey Vlad, make sure you check your ELT before every flight.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
