Old 09-26-2020, 07:35 PM
bnovak1220 bnovak1220 is offline
Default IO-540 engine mount brackets (boss)
Hello all,
So I started today to mount my engine on the plane. Lycoming sent the engine with the mounting brackets for me to install. My question is what tool do you use to tightened the forward two nuts on each bracket - especially the ones on the bottom of the engine. A socket doesn’t fit and my crowsfoot doesn’t work either. Not to mention these probably need to be torqued to ( my guess around 190 in lb) there was no manual or documents with the engine giving specs. (Plan on calling Lycoming about this Monday)
One thought I had was to file down the crowsfoot but see this could just break when I try to get the correct torque.
Any advise you guys have would be most welcome 🙏
-Berkley
Old 09-26-2020, 09:01 PM
lr172 lr172 is offline
You should consider adding wrenches to your arsenal. I find them to be indispensable when doing engine work. I had no issues getting those nuts tight with a wrench.
Larry
Old 09-27-2020, 06:33 AM
Thanks for replying Larry.
Umm yes I have a ton of wrenches. I am going to attempt to attach pictures so that everyone can see what I am trying to do. A Standard 9/16" wrench will not even get a good bite on this bottom nut and even if it did there is no room to turn it. (not alone get a torque value on it - which perhaps it doesn't need but am going to call Lycoming Monday about it)
So anyone if there is a special tool (or special wrench) you used to get these tight please let me know.
Thanks in Advance!
ID:	2876  Click image for larger version
-Berkley
Old 09-27-2020, 06:45 AM
Plummit's Avatar
Plummit Plummit is offline
Default U joint socket
Can you get a "U" joint socket in there? I'm not talking about adding a U joint to a socket, but rather a socket with a U joint built in.
https://www.homedepot.com/p/TEKTON-3...8016/310620894
-Marc
RV-10
N814RV
2020 Donation Made
Old 09-27-2020, 06:50 AM
Thanks in Advance!
Your pan looks like it may be different than mine. It was too long ago to remember what I did, but I know that I didn't have to use special tools. I remember one of the nuts requiring some creativity. I think you have to trust the forearm torque wrench in this application.
If you continue to struggle, I am sure you can make a socket fit with creative grinding with a cut off tool.
Larry
Old 09-27-2020, 08:00 AM
9GT's Avatar
9GT 9GT is offline
I am pretty sure I used my cylinder wrench's to get those nuts torqued IIRC on my IO-540. I do have a pretty good arsenal of modified wrenches for specific applications though: cut, grind, and weld, until they work.
David C.
Howell, MI
Old 09-27-2020, 08:26 AM
Mitch757 Mitch757 is offline
Yes, cylinder wrench works great. Just used one on neighbor's RV12.
Old 09-27-2020, 10:43 AM
Hey Guys
Thanks for all the replies!
Is this the kind of cylinder wrench you are talking about?
-Berkley
Old 09-27-2020, 01:47 PM
9GT's Avatar
9GT 9GT is offline
Hey Guys
Yes one of those.
David C.
Howell, MI
