Old 08-31-2020, 06:54 AM
Rumbling Thunder's Avatar
Rumbling Thunder Rumbling Thunder is offline
Default Acceptable Landing Areas
What are the types of runways that RV8s can land at? Grass strips, tarmac, etc?
United We Stand, Divided We Fall
Old 08-31-2020, 07:11 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I live on a grass runway airport so that's the majority of my operations with my RV8.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 08-31-2020, 07:24 AM
Taltruda Taltruda is offline
You specify said "RV8s" so I'll assume not an A model? I would say you could land a RV-8 on grass, gravel, tarmac, even paved runways. A concern may be gravel or soft ground and how much clearance you have in your wheel pants (if installed) or if the pants aren't installed, are you willing to risk damage to the horizontal from rock chips. .
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
Old 08-31-2020, 12:48 PM
Low Pass's Avatar
Low Pass Low Pass is offline
RV-8 "can" land on gravel, dirt, grass, asphalt, concrete. Just can't tolerate excessively soft surfaces, rocks/gravel larger than ~1", uneven surfaces. Paint dings and chips are the price you pay for gravel and small rock operations.
Bryan
Houston
Old 09-07-2020, 11:55 PM
RhinoDrvr RhinoDrvr is offline
I would operate off smooth maintained grass or tarmac. But I’ve seen enough landing gear issues with the -8’s (main landing gear bolts coming loose, tailwheel stingers wearing and requiring oversized fasteners, tailwheel weldments coming loose) that I’d have my reservations operating off anything unprepared.
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 09-08-2020, 07:55 PM
donaziza's Avatar
donaziza donaziza is offline
Default "Tall" grass strip
I've landed on grass strips with my 8 a number of times. But one time, the grass was so #%^& tall, I took my wheel pants off before leaving.
