Old 09-05-2020, 01:47 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Hangar floor mat ideas?
For those with hangars, especially in cold areas... any tips.
Looking for a nice looking floor covering/pad system.
Costco and HD have various garage floors that snap in sections or come in rolls. Just wonder what looks nice, easy to keep clean, allows plane to roll ok but provides some insulation/padding.cushion when working or hanging out with plane in the cold times?
Any tips and pics welcome. Thanks.
Swisstrax seems like the winner so far but a bit spendy.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 09-05-2020, 04:41 PM
Martyrv6a Martyrv6a is offline
I scavenged some carpet that was being replaced in a office building and just doubled layered in my work area. Drop tools and parts don’t break or fly off the concrete to dark corners.
Old 09-05-2020, 06:20 PM
Have you considered used football or soccer field turf? It would not be the easiest to pick up a dropped nut or rivet but would be nice to work off of. There are several repurpose businesses that sell ignore very reasonable.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 09-05-2020, 06:43 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
^^^ THIS ^^^
Is the same thing I did. Cheap and works just fine for me.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 09-05-2020, 06:45 PM
Find a local commercial (not residential) carpet dealer. Ask about carpet tile options. You can tack it down with double sided tape.
You should be able to find options anywhere from $1/sf and up. Sometimes they have overstock they will let go of for substantially less.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-05-2020, 08:06 PM
RV7 To Go RV7 To Go is offline
+1 on the carpet tile.
One of the guys on the field got some that was being replaced from a hospital. He just laid it down on the floor and cut the pieces he needed to fit the sides. Looks fine and does the job of keeping things a little less cold in winter. Still able to work off a creaper and find dropped parts on the short pile.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 09-06-2020, 04:06 AM
plehrke's Avatar
plehrke plehrke is offline
I have used carpet and also a few of the 2’x2’ snap together squares. Used both only in front of work bench or around plane. Very pricey to do my entire 50x50 hangar.
I think it helps some to not stand on concrete floor but never liked how dirty it became and difficult to clean. Lots of dirt, dust, metal chips, etc in the carpet. Squares a bit easier to take outside and brush off. Now that I am no longer building I have nothing on the floor to make easy to sweep.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 09-06-2020, 08:29 AM
Whitman Whitman is offline
I don’t know how nice your hangar is, but a lot of car guys use this for their garages. Expensive but very nice and high quality! I’d be careful with carpet since it’s so flammable.
https://racedeck.com/
RV-4, #audiaviator
"Poise under pressure is the single most valuable thing you can have as a pilot. Make mistakes, take corrective action as quickly and calmly as possible and press on."
Old 09-06-2020, 09:10 AM
Nylon carpet is self-extinguishing when set on fire. Commercial grade carpet with a Class 1 fire rating is used in schools, hotels, etc., all of which have pretty stringent flammability requirements. All bets are off if you soak it in petrochemicals.
Which is why carpet tile is a good choice. Dump a quart of oil on it? Throw away those tiles, re-arrange the rest, and move on.
(Disclaimer. I work in and took part in designing the two largest carpet tile manufacturing plants (2 of 'em) in the world...)
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-06-2020, 09:18 AM
brown bear brown bear is offline
I have looked at this https://www.bltllc.com/gfloor-universal-flooring/
