Old 08-30-2020, 03:27 PM
Eric Minnis Eric Minnis is offline
Default Ipad or the new Aera 760?
About to get a little addition to my panel and wanted some opinions. I currently have a 10" G3X Touch with a Garmin GTX335 Xpdr/ GTR 200B comm/ GDL 50R ADSB with bluetooth.
I am wanting to add a handheld device that I can use to make flight plans, check weather etc away from the airplane. I like foreflight, I also like the idea of just using the Aera 7" 760 and how the Garmin stuff interacts.
If you could just choose 1, which would it be? The Ipad with Foreflight or the Aera 760 running Garmin Pilot?
Thanks for the ideas!
Eric
Old 08-30-2020, 03:58 PM
If money was no object, I'd take the Aera.
I'm faced with more or less the same situation and will probably be going with the iPad I already own for now, but will probably upgrade to the Aera at some point.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-30-2020, 07:50 PM
mfleming's Avatar
mfleming mfleming is offline
If you decide you don't like the Garmin product and want to continue with Foreflight you have a lot invested and who knows what the resale value will be.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 08-31-2020, 07:00 AM
olyolson's Avatar
olyolson olyolson is offline
Default Aera 760 vs Ipad
Eric,
Go with the Aera 760, I have an AFS EFIS which I love and an IPad MIni I use to display backup navigation, approach charts and listen to music. The IPad is basically worthless on a sunny day cause I can never get it bright enough in the bubble canopy of the RV-8. I have an Aera 660 mounted in the panel for backup navigation and to control the Garmin VIRB cameras. The 660 screen is plenty bright and not even a comparison to the IPad.
I know lots of guys use the IPad and like it but I am not a fan. Borrow someone’s IPad and try it on a flight and see for yourself. The Garmin Aera units are pretty full function devices and they’re easy to navigate between multiple useful menus.
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 08-31-2020, 03:03 PM
gyoung's Avatar
gyoung gyoung is offline
If your Burlington is Vermont, you may not have heat concerns but here in Houston it makes a difference. My iPad overheats easily and often but my panel mounted 796 never has and is readable in direct sun. I use the iPad for flight planning and carry it along but don't count on it in flight.
Greg
1950 Navion - flying
RV-6 - 18 yrs and 99.5% done
1940 Rearwin Cloudster project next
4 L-2 projects on deck
Old 08-31-2020, 04:18 PM
jliltd jliltd is offline
aera 760. With your flight deck it is no contest as far as I'm concerned.
RV-8
(a few more airplanes too)
Old 08-31-2020, 04:20 PM
And further, if you want to flush mount the aera 760 the panel dock from gpsdock1 is fantastic (designed by fellow VAFer).
https://www.gpsdock1.com/
RV-8
Old 09-01-2020, 05:22 AM
Thanks for all that commented...... I ordered the Aera 760. I plan to order that nifty panel dock as well.
Eric
