Old 08-29-2020, 09:22 PM
Reflex Reflex is offline
Default Question on JetFlex WR....
Painted the interior of my fuse today. While test shoots went very well, it appears that I either had my air pressure to high or my paint too dry when the fuse was painted. The result was a very rough finish. I was working for a smooth finish.
Anybody know what is needed to re-coat the WR type of JetFlex interior paint? Can it be recoated without sanding if it's done soon enough after spraying? This stuff is about as rough as anything I've seen.
Fred
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
Old 08-29-2020, 09:39 PM
mfleming's Avatar
mfleming mfleming is offline
I had the same result with JetFlex WR. I believe it was because I couldn't keep the paint gun at an even distance due to the long reach and odd angles.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 08-29-2020, 10:32 PM
az_gila's Avatar
az_gila az_gila is offline
<Try thinning it down to 15% or so if you are in a dry/hot climate.>
Correction - the max limit in the data sheet is 25% - aim for that least that level.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-29-2020, 10:39 PM
bruceh's Avatar
bruceh bruceh is offline
I had to add quite a bit more water to thin the paint than was suggested.
Bruce Hill
2020 VAF donator
Old 08-30-2020, 04:32 AM
Many thanks for the tips. Paint was reduced 20% when I shot it. Went back out to the shop last night and reduced air pressure and got good results.
Anybody know the right procedure to sand and re-shoot JetFlex WR?
Dues Paid for 2020
RV-14
Old 08-30-2020, 12:51 PM
MED MED is offline
As already suggested, additional water will help. I was fortunate, though. When I sprayed my interior, first glance said I might have to remove it for orange peel. An hour later, it had self leveled. I found it very forgiving for a first time painter. YMMV.
MED
140236
N435MD
Miss March 2020
Old 08-30-2020, 01:12 PM
rapid_ascent rapid_ascent is offline
I'm almost to the same point. I did part of the interior but I need to do the remainder. I've been delaying as much as possible but its a big step and once its done I don't want to scratch it.
I sprayed my flap motor covers separately and I got some orange peel. I think it will take some sanding prior to repainting. This stuff is actually pretty tough once it completely dries so I would suggest you start sanding sooner rather than later.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-30-2020, 03:29 PM
It's been determined that my paint mix was fine.
At issue was the supply pressure to the gun. I misunderstood the instruction I was given. Max supply pressure is 30psi, I took this to mean dynamic (when the trigger is pressed). The max supply pressure is evidently a static reading.
Dues Paid for 2020
RV-14
Old 08-30-2020, 03:35 PM
wirejock's Avatar
wirejock wirejock is offline
Default Sanding
No idea on water based but it is an epoxy so a wet sand with 400 should smooth it out.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-31-2020, 05:04 AM
Larry,
Thanks, I figured as much. Started the process last night. Planning on smoothing out with 350 - 400 grit and to give the first layer some "tooth" then correct the mistake and re-shoot.
One thing is for sure, the way this stuff sands after only 24 hours, it should make one heck of a good coating for the interior.
Fred
Dues Paid for 2020
RV-14
