08-24-2020, 06:49 PM
Air flow visualization liquids and interpretation.
I hope this is the correct forum.
There have been comments by Dave Anders, SCSmith, and written briefly in the RVAtor. They mention using a fluid on the gear fairings and wheel pants to ensure they are truly aligned with the airflow. Dave Anders mentioned several times of mixing tempera paint powder in some engine oil and (somehow) applying to the gear fairing and getting them aligned. The same for wheel pants.
So, how exactly are these applied (eye dropper?), in a line or literally drops? And what colors work and don't stain the paint? Should they be UV, fluorescent? I have bookmarked 4-5 sites where these can be purchased.
Then, after the flight test and landed again, how are the results interpreted? What am I looking for, even streams all the way to the TE?
Can some of you experienced guys sound off on this, Please.
Bill
RV-7
Lord Kelvin:
08-24-2020, 07:57 PM
There are a variety of techniques and materials, and a whole treatise (or two) could be written about it.
If you have a white or light-colored surface, just plain used motor oil is best. It has extremely fine particulates and flows smoothly. Adding tempera paint to clean oil will let you change color, so for example if you have a dark surface, use white tempera paint. But it is very hard to mix and filter this paint-oil mix well enough to not have it be somewhat gritty. For gross flow visualization, that may be just fine, depending on your purposes. But the grit will trip a laminar boundary layer early, so it is not useful for visualizing laminar separation, laminar bubbles, or transition.
There are several application techniques too. For streamline visualization, just paint it on over the whole surface. One way to produce really dramatic visualizations of separated flow is to put a stripe of paint-oil along the forward portion of a surface, or a row of dots, and then fly. The paint-oil will flow back, but can not get inside the separation zones, and so will leave those areas completely uncoated. With highly 3-D separation (such as a vortex sheet formation) you may see the oil run around the separation point and fill in behind it, perhaps showing surface vorticity, or creating a number of interesting patterns.
If your goal is to just be sure a surface is aligned to the flow (zero angle of attack) then coat both sides and then check that the attachment line is right on the leading edge. From the leading edge back, it is unlikely that the 'upper' and 'lower' surface will look much different for something like a strut fairing or wheel pant, even if it is at some angle of attack, because there is little if any flow separation, but you will see the attachment line move off the leading edge.
Now the biggest challenge for flight test. You put the stuff on on the ground, and then taxi, take-off, climb, cruise, descend, and land. What part of that flight gets imprinted in the oil flow patterns? It depends. If you put enough on to keep it wet during the whole flight, then it will be biased toward the end of the flight in terms of what has the most influence. Flow character from early in the flight will get 'erased' by additional flow later in the flight.
For some things, you may not care. Certainly landing gear strut alignment to the flow is somewhat sensitive to angle of attack (speed).
Another challenge is gravitational effects on the oil before, during, and after the flight.
A couple of choices: If you put a thin paint-oil mix on, and cruise until it actually dries, then the patterns of flow will be more or less preserved at that flight condition and not corrupted by the landing phase of flight. If you can mount a camera that can see the area of interest, you may be able to record the flow behavior at the desired flight condition, or maybe even more than one condition.
Interpreting results is challenging and interesting, and especially for highly 3-D flows, you can not assume that the flow on the surface is the same as the flow a short distance up off the surface. Examples are spanwise flow on swept wings, especially on the underside in areas of fairly slow streamwise flow component, and areas like the belly just behind the cooling flow exit, where you can very likely see vorticity/recirculation on the surface, but a short distance up off the surface the flow could be perfectly-well organized.
Getting the oil viscosity what you want can also be tricky, and depends on what you want to visualize. If you want to make a pigmented coating that will 'dry' at some point in the flight, then thinner oils are better. If you want to keep everything wet and flowing, heavier oils are better. You will likely find that in areas of high surface shear stress, like the forward portion of an airfoil, the coating may be wiped fairly clean. That is a useful result in itself, it tells you the flow is attached and high velocity near the surface. All that oil has to go somewhere and it will thicken in areas of lower shear stress or lower velocity. Interpreting sudden changes in residual oil can be tricky - it could be transition, it could be a laminar bubble, it could be separation. It takes experience with these to recognize tell-tail signs of each.
I will follow with a few stories, and answer what questions I can.
Oh and full disclaimer - I take no resposibility for whether oil or paint stains or discolors your airplane. I can not promise that a good coat of wax will prevent it, although it seems like it would help, but it may prevent the oil from wetting to the surface, and give different/spurious results.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
08-24-2020, 08:41 PM
Thanks, Steve that is a lot of typing!! I downloaded some NASA papers on visualizing the flow, and got some idea of the challenge of viscosity, evaporation and gravity effects. I have some large paint samples I can test for staining. The pants are dark/light so maybe alternating colors. I read to mix pigments to small amounts of oil first in a thick paste to prevent clumping, we shall see how that works.
Well off to this new educational venture. I'll post some photos for interpretation.
Bill
RV-7
Lord Kelvin:
08-25-2020, 12:00 PM
Continued...
One other tidbit I forgot to mention about oil flow visualization is use of UV pigments. It is not very useful for flight test, unless you want to test at night with no moon, and have a way to bombard the area with UV light. But Aeroshell 100 has a UV pigment that is useful for finding oil leaks on engines, all you need is a hand-held UV light and you can see the green flourescence of the oil. We sometimes use this in wind tunnel flow visualization. It doesn't matter what color the surface is.
Another flow visualization technique that can be useful in flight test, especially if you have very dark colored surfaces is sublimation. Polycyclic aromatic hydrocarbons (PAHs) sublimate (evaporate directly from solid to gas) and the rate of sublimation depends on local pressure, temperature, surface shear stress. You can apply a sublimating coating by dissolving the material in a carrier and spraying it onto the surface. The carrier solvent flashes off leaving a fairly smooth coating. For atmospheric pressure and our typical flight speeds, napthalene works pretty well. For higher flight speeds, you want PAHs that sublimate slower. In supersonic wind tunnels, we use fluorene.
The primary use for sublimation is to identify laminar transition. There is an abrupt increase in surface shear stress where the boundary layer transitions from laminar to turbulent. So if you have a laminar flow airfoil that is coated with napthalene, and you watch the material progressively sublimate off the surface, you will see that the material disappears much more quickly under a turbulent boundary layer, and more slowly under a laminar boundary layer, because of the difference in surface shear stress. As you watch the material sublimation progress, it will later start to disappear in the forward portions of the laminar area as well, because the shear stress is higher there than farther aft. Finally, you may end up with just a stripe of remaining material just ahead of transition, illustrating a laminar separation bubble, where the shear stress is very low. Finally, all the coating will sublimate away. This whole process may take 3--5 minutes. So typically you would image the surfaces of interest in flight, but it is possible to do a very short flight and land and then image the results. Again that complicates the results because of the non-constant flight conditions that the boundary layers have been subjected to. I have used sublimation on sailplane winglets; we flew a constant speed on tow and I imaged the winglet from the cockpit.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
08-25-2020, 12:39 PM
Just for general interest, I thought I would share one story about a rather unique flow visualization experiment that was done at the (then) NACA Ames Aeronautical Laboratory. (Now NASA Ames Research Center).
Shortly after WW II, the NACA was approached to try to understand why the P-51 Mustang successfully used the NACA 6-series laminar flow airfoils while the Bell P-63 King Cobra, using similar airfoils, did not achieve the significant performance benefit expected. The question fell to a young engineer named John Spreiter. John wanted to do sublimation testing on both airplanes to determine the extent of laminar flow achieved. But how to do that???
Just a short distance from the lab there was a cement plant that, before the days of scrubbers and other polution-controls, would emit an alkaline plume that would extend quite high, especially on cool summer mornings when the marine layer would intrude into the bay area. John found a chemical ( I don't know what it was) that would sublimate rapidly when subjected to the alkaline vapor in the plume. He applied the material to the wing of the airplane, and the test pilot would take off, turn downwind in the pattern, fly through the plume at the cement plant, and land. The team would then rush out and photograph the wings. Areas of laminar flow have much less mixing and less shear stress, thus much less exposure of the surface to the alkaline vapor, whereas areas of turbulent boundary layers have much higher mixing, and so the sublimation coating would preferentially 'clear' in those areas.
His finding was that indeed, the P-63 achieved far less laminar flow, despite using airfoils from the same family. John found that the P-51 was built with heavier wing skins that tended to form smoother surfaces, whereas the P-63 was built with lighter skins that were wavier, especially where riveted to ribs. The P-63 also used thicker airfoils, which make sustaining laminar flow more challenging and more susceptible to surface waviness causing early transition.
John Spreiter had a successful and rewarding career, doing pioneering work in transonic and supersonic aerodynamics, interaction of solar wind with planetary ionospheres, and was a wonderful teacher and storyteller. I was blessed to take several classes from him late in his teaching career, and forever grateful that he agreed to serve on my doctoral committee despite having retired a few years before.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
08-25-2020, 01:20 PM
Would that be the same cement plant that, for years, was a vfr waypoint for traffic going into San Carlos airport?
08-25-2020, 01:26 PM
Great info Steve
I really enjoy reading this info, Steve. More reminders of how much there is to learn about this amazing hobby!
08-25-2020, 01:42 PM
HI Bob,
very likely a different one. There used to be several batch plants on the peninsula. The biggest of course was always the Permanente plant in the Los Altos-Cupertino hills. But this one was at the corner of Moffett Blvd and US-101 in Mt View. I think the one you are referring to was near Harbor Blvd and US-101 in Redwood City? Its been a long time!
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
08-25-2020, 02:44 PM
Report the Cement Plant
I thought exactly the same thing when I saw this. But I think it is more likely to be the Permanente Ridge cement plant that is directly South West of Moffett. https://en.wikipedia.org/wiki/Permanente_Quarry
I'm based out of KSQL, so "Report the Cement Plant" is still something I have stuck in my head. I believe you can still get a shirt from the San Carlos Flight Center that says exactly that.
Kevin R. Walsh
Cozy Mk-IV
08-25-2020, 06:08 PM
Dan Horton
RV-8 SS
Barrett IO-390
