Old 08-10-2020, 06:07 PM
Jab Jab is offline
Default Exhaust repair Knoxville
Hi guys
I live in the Knoxville area and need my exhaust welded, I would appreciate any recommendations as I am new to the area, a google search did not turn up much.
Gary
Bought RV-4
KRKW
Old 08-11-2020, 11:03 AM
fixnflyguy fixnflyguy is offline
Default Pics?
You would likely get more input with a picture or two and type of system. Even if you dont know the type, likely a viewer will. Most systems are made up of several pieces that are slip jointed together, and will require some disassembly to facilitate welding.May be easiest to send off to someone.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 08-11-2020, 05:57 PM
Jab Jab is offline
Thanks Bill. It’s broken off at the flange where it attaches to the cylinder, it’s a crossover 4 into 2 System and I may try to find a used one. I had to leave for work so I cannot get photos, the goal was to find a shop that knows how to weld Inconel, or whatever the exhaust is made of.
Bought RV-4
KRKW
Old 08-11-2020, 06:22 PM
FORANE's Avatar
FORANE FORANE is offline
I have a crossover 4 into 2 on my lancair that repeatedly cracked at the flange of #4. After welding it a couple times we ended up with the additional strength added as seen in the pic. 1st pic I have uploaded to the site; a great addition.
The guy I use isn't an aircraft specialist but knows how to weld. He's in Elizabethton TN.
Lancair 235/340
RV-9A (2013 - 2016)
Old 08-11-2020, 06:35 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Default Check with Craig at Vetterman
Gary,
The first time my exhaust broke at the flange a local (SKILLED) car guy welded it. Looked beautiful. When I found the same flange had then cracked again I sent it to Craig at Vetterman Exhaust. Craig welded and reinforced the broken area. He apologized that it took him 2 days to do the repair, something about his wife giving birth to new baby..... Each repair cost about $20 as I recall.
http://www.vettermanexhaust.com/
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
Old 08-11-2020, 09:35 PM
Jab Jab is offline
Thank you for the suggestions gentlemen, Elizabethton is doable for me to drive and Larry Vetterman is first class, I will see what’s going to work when I get home.
Bought RV-4
KRKW
Old 08-12-2020, 09:50 AM
Roy Thoma's Avatar
Default Picture of Vetterman’s repair
Vetterman’s welded a pair of half circular reinforcements when repairing my exhaust flange.
Roy
Old 08-12-2020, 07:02 PM
georgedouglas georgedouglas is offline
Originally Posted by Jab View Post
Hi guys
Gary
Gary, I am the President of our Knoxville EAA chapter 17 and may be able to find you a welder in our group. Contact me at george@oilhelp.com.
george
Old 08-13-2020, 11:51 AM
Jab Jab is offline
Thanks again for the help. George, I will be in touch.
Bought RV-4
KRKW
Old 08-15-2020, 08:37 AM
penguin penguin is offline
Send it back to Vetterman, their repairs are very, very good. It may take a day or two longer but anything else may well turn out to be only temporary.
