Old 08-07-2020, 06:14 PM
pereeder pereeder is offline
Default OK to Hang Engine on 7A without wings?
Hello All-
I'm finally at the point of buying the power plant & prop. Wingless 7A fuselage in a single car garage, no wheels at all. Wings previously fitted.
Question: Is it OK to mount the mains and nose gear without the wings installed, then hang the engine? I'm concerned about damage to the main spar center section, without the wing spars in place.
I was thinking of making some precision spacers in place of the wing spars, then running the large wing bolts (hardware store) through the spacers to temporarily secure the main gear.
Paul Reeder
-7A, Central Ohio
Old 08-07-2020, 06:50 PM
RV7 To Go RV7 To Go is offline
I used 4 spacers (top and bottom at each end in the 1/4" holes just ahead of the main bolts) to maintain position of the main spar. Engine was hung and FWF stuff done before taking it to the hangar to plug in the wings in. Loosened the spacer bolts and plugged in the wings. No issues experienced.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 08-07-2020, 06:53 PM
wirejock's Avatar
wirejock wirejock is offline
Default Spacers
Good point. Almost there myself. I will bolt the Buller Spacers back in place before hanging the engjne.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I don't know of anyone that did not do landing gear and hang engine before final wing installation. Just don't try to start without wings. Plane needs them for damping otherwise it could shakes like a wet dog as Vans tells it and cause damage to the structure.
Scott- 2020 donation
New RV-7A N579RV, only 80 hours now without 2020 fly-in destinations
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
Old 08-07-2020, 07:23 PM
Hitt7A Hitt7A is offline
I installed mine no spacers and didn’t have any issues, put the wings on later and everything lined up good. I agree I wouldn’t start it up without the wings on.
Old 08-08-2020, 07:43 AM
Thanks Guys, particularly the "Wet Dog" advice. LOL. That I did not consider
-Paul Reeder
RV-7A, Central Ohio
90% done, 50% to go...
Old 08-08-2020, 10:01 AM
Ralph Inkster Ralph Inkster is offline
If you don't have the empennage attached, throw some weight on back there.
& I definitely agree with others about the no start with wings off rule. There's a YouTube video (from our airfield) of a turbine 4P skipping across the ramp on it's side... expensive mistake!
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 08-08-2020, 10:51 AM
Aero_Octaveus Aero_Octaveus is offline
No gonna sugar coat it. I kinda want to see that clip
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
Old 08-08-2020, 11:30 AM
Robertc's Avatar
Robertc Robertc is offline
I think this is it.
http://m.youtube.com/watch?v=EHt6nYTdmRQ
Old 08-08-2020, 11:33 AM
Yeh, wasn't a good day for them.
Ralph
