Old 07-27-2020, 05:38 PM
Caribbean10 Caribbean10 is offline
Default Countersinking rudder horn
I just started the rudder and got to the point where I need to countersink the rudder horn. One side of the horn is easily accessible and countersinkable, but the other side, the holes are near a bend in the horn and the countersink cage is not able to sit flat. How did you guys manage to countersink those two holes? (7-4 step 2)
Old 07-28-2020, 01:11 AM
rdamazio's Avatar
rdamazio rdamazio is offline
Without the cage?
There's a bunch of those cases throughout the build - you can do it manually by attaching the countersink tip to a rotary-type deburring tool, or to a drill (go *very slowly* so you don't countersink too far). I prefer doing it manually myself, even if the end result is not as smooth as when done with the drill.
Alternatively, if you want to spend the money, there are long-nosed countersinking tools, like this: https://www.aircraftspruce.com/catal....php?PANEL=203
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 07-28-2020, 05:37 AM
Yeah I was going to take off the cage, but figured, hey, let's see what other people do...
I think I'm going to buy a hand held rotary deburring tool for this, since I'm sure I'll need it at some point in the future too.
