  #11
Old 07-27-2020, 07:12 PM
N184DA's Avatar
N184DA N184DA is offline
I only use flaps in my RV4 for takeoff when I have a rear-seater.
Makes it easier (& quicker) to transition from the three-point attitude.
Derrick L. Aubuchon
RV4 (Flying, approx 900hrs)
Tacoma Narrows Airport (TIW)
dlaubuchon@gmail.com
(2020 dues paid)
Old 07-27-2020, 07:16 PM
AlexPeterson's Avatar
I've used about 1/3 to 1/2 flaps for almost every takeoff, maybe 2200 of them so far. My flap switch is just to the left of the throttle knob, so I only have to move my thumb over to put them up once I see about 70-75 knots. I like the visibility over the nose better during the initial airborne phase, and the airplane is in trim during the transition from just airborne through 130 knot climb speed, without changing the trim position much. The liftoff speed is a bit slower, and comes a lot sooner with some flaps in.
On a go around, it will be very unlikely that I'll forget to raise the flaps, as it is a normal procedure for me (as others have mentioned).
Disadvantages: takes a bit higher groundspeed to lift the nose wheel, and a flight would need to be aborted if the flaps didn't come up.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 07-27-2020, 07:52 PM
KRviator's Avatar
KRviator KRviator is offline
I use flaps every takeoff, no exceptions and peg the speed at Vy for the first 30 seconds no matter where I am. That, typically, gets me high enough I can return to the runway.
My home strip is grass & gravel, short, on top of a plateau and surrounded by trees, exactly the place you do not want an engine failure. The faster I can get higher, the better the chance I have of being able to clear the trees and make it to a clearing or nearby road.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 07-27-2020, 08:53 PM
gereed75 gereed75 is offline
Thanks for the food for thought Mel.
Although the airliner example is certainly true, it is a bit apples to oranges to our case. Our fat short Hersey bar wings perform very differently than an airliner wing optimized for high altitude cruise. A no flap takeoff in a 767 would take a LOT of runway.
AFAIK L/d max is achieved flaps up. Never flew any best glide profiles with the flaps partially down. Yep you may produce more lift at the same speed with partial flaps, but you will also produce more induced drag.
Simple test might be timing successive take offs, 0 to 80 knots, 80 knot climb to 300’. There might be some combination of partial flaps that get you there quicker, but I suspect it will be within a few seconds either way.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 07-27-2020, 11:00 PM
andrewtac andrewtac is offline
https://vansairforce.com/community/s...d.php?t=134158
I believe flaps 10 in the 8 was the best compromise, which I do on all takeoffs.
Mark Andrew Tacquard
2019 VAF Dues Paid
RV8 N189DK
Old 07-28-2020, 06:22 AM
Mark, Thanks for that link. Very interesting data, thanks Nigel.
Interesting that with that data, Nigel and a couple of other sage flyers stated a choice to do normal take offs from paved runways no flaps. I also suspect that most people use a higher airspeed than 1.2 Vs during climb out on TO. The nose attitude at 1.2 Vs would not be a fun place to be with a sudden engine failure after TO.
Again, many pros and cons to weigh here.
Gary Reed
RV-6 IO-360
Old 07-28-2020, 10:11 AM
RV6_flyer's Avatar
Have read this thread a couple of times.
I rarely use flaps except on grass. I have forgotten to retract flaps taking off on pavement once. The amount of trim needed is how I knew flaps were down.
Starting to think about using flaps more often to become more like Mel developing a reflex action check to make sure they are up.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 07-28-2020, 10:15 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by Mel View Post
Flaps are not only for drag. They also produce lift. Why do you think airliners use flaps for take off? On the RV series of aircraft the range of 15° flap is pretty close to best L/D. At this point you are producing more lift than drag.
With proper use of flaps, you will be at a higher altitude when your failure occurs.
Another good post where I would have used a LIKE button here if it were available instead of posting to say I AGREE.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 07-28-2020, 10:18 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Flaps
I quickly transitioned to using flaps during takeoffs in my -8, ...
it seems to reduce/eliminate the "skittering around" just prior to liftoff.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
Old 07-28-2020, 10:19 AM
Pilot135pd's Avatar
I'd move it to the ADVANTAGES. Wouldn't it be better to know your flaps aren't working as you depart your home base instead of finding out when you use them to land at another airport and then find out they don't retract?
