Old 07-24-2020, 11:39 AM
Davea320 Davea320 is offline
Default Basis question
Anyone have a good idea/technique for deburring the back side of a hole that is inaccessible with the standard countersink/deburring tool? Been struggling with this issue during entire build.
RV7 QB started 1/17
Working on FWF
2020 dues sent
Old 07-24-2020, 11:41 AM
AlpineYoda AlpineYoda is offline
Would the tip of a file reach the hole? A fine file rubbed over the surface might debur.
I've also found that a good scrubbing with purple scotchbrite pads debur decently, as long as you don't mind the surface getting scratched up. If this hole is inside the plane, you probably don't mind scratches.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Tail finished March 2020
Wings finished July 2020
Fuselage joined to tailcone on July 19, 2020
N1814T reserved with FAA
Donated through 12/31/2020, EAA and AOPA member
When it absolutely, positively doesn't matter when or if it ever gets there, ship with Old Dominion.
Old 07-24-2020, 11:50 AM
Aluminum Aluminum is offline
Here's a good tool for that task:
https://www.aircraftspruce.com/catal...?clickkey=7152
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
Old 07-24-2020, 11:52 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
https://www.cleavelandtool.com/produ...18378209656894
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-24-2020, 01:11 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Burraway tool
Debur 3/32, 1/8 (and some other larger sizes) front and rear side of hole in single pass. Loved this when doing the flange holes on ribs or hard to access areas.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-24-2020, 01:30 PM
terrye terrye is offline
Default Blind Deburring Tool
I've used these with great success
https://www.noga.com/Products/rvcn/R...20countersinks
Look under "Tools"
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 07-24-2020, 04:22 PM
wirejock's Avatar
wirejock wirejock is online now
Default Right angle debur tool
If there's room, I use this.
https://drive.google.com/open?id=0B7...VRCSlNLUjI4c0E
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-24-2020, 07:25 PM
jcarne's Avatar
jcarne jcarne is offline
I use exactly what Mike S posted. Just have go have the right attachment, you want the deep U attachment.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 07-25-2020, 12:05 AM
RV7A Flyer's Avatar
I picked up a set of these in a bunch of sizes off of Ebay...new ones are pricey. Replacement blades are available, as well, and not very expensive. You can set the tension on them, as well, to more or less aggressive in how much metal they remove.
A terrific tool, one I really liked and highly recommend.
2019 Dues paid!
Old 07-26-2020, 03:31 AM
RViator60 RViator60 is offline
I highly recommend getting the 3/32 and 1/8 Burraways. A little pricey, but well worth it. https://cogsdill.com/products/deburring-tools/burraway
Their website has nice videos showing how they work, how to change blades, etc. I think I picked mine up from ATS or Brown Tools.
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wings and fuel tanks completed,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite delivered.
- Currently working on fuselage
https://eaabuilderslog.org/?s=MartysRV14A
