Old 07-21-2020, 09:40 PM
Jarrett Jarrett is offline
Default HS-905 Nose Rib Fluting
I'm currently fluting the ribs in preparation for final assembly of the horizontal stabilizer. The only ribs I can't figure out how to flute are the nose ribs. There's only really one place that I can significantly flute near the aft portion and it gets the holes almost lined up, but just not enough. I've tried fluting closer to the front, however this leads to the flange bending outwards, so I have to un bend it to a point that it doesn't really make a difference.
https://photos.app.goo.gl/KPXzJFPeQiFBG7N69
https://photos.app.goo.gl/vraykQs2Quxs1yyLA
https://photos.app.goo.gl/VeWXtw53hW8on5pH9
I'm not sure if I should try to align the holes better, or if I should call them good enough and build on. Thanks!
Jarrett
Calgary, Canada
RV-14A
Old 07-22-2020, 04:42 PM
Got off the phone with Van's today and they said it's good to go!
Jarrett
Calgary, Canada
RV-14A
