Old 07-19-2020, 06:12 AM
airshawn58 airshawn58 is offline
Default Hot Start with E-Mags?
I recently purchased an RV 7A. It has fueL injection, one conventional and one E-mag. The other day someone suggested I never use the tried-and-true hot-start method to start the plane; that it is harmful to the E-mag.
Thoughts?
Thanks, sle
Old 07-19-2020, 06:39 AM
Bavafa Bavafa is offline
Did he/she offer any reason or logic to back up his suggestion?
To harm it?!?!??!?!?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 07-19-2020, 06:51 AM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
I have an E Mag and magneto on my RV6 with fuel injection. My hot starts I always start at idle cut off and the throttle open a little. This is the same way I started it with 2 mags.
RV6 N7219d
IO-320-B1A
Sam James cowl
first flight May 2, 1997
RV8 #83830 tail done, wing done
Fuselage started
Old 07-19-2020, 08:59 AM
mike newall's Avatar
mike newall mike newall is offline
Plus 1 on that.....
Starts perfectly, however......
If you have stopped for say 10 minutes, when you start again, there may be some stumbling and missing for a few minutes - just vapour in the lines as the Lycoming doesn't have a return loop system.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 07-19-2020, 09:11 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Wouldn't it be logical to expect Emagair to note that a particular hot start technique is a problem? Yet they don't. Call Emagair and ask them. I would bet that your "source" at the airport also thinks LOP is a bad idea
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 07-19-2020, 09:19 AM
lr172 lr172 is offline
Must research the source and use judgement in accepting advice like this. Many suggest that walking under a ladder will create adverse consequences.
I remember my transition training CFI adamantely suggesting that I prime my carb'ed engine by pumping the throttle. Most know that when this is done with the engine not spinning, it loads the FAB with raw fuel and creates a serious risk of engine fire if you get a backfire. While the CFI had no idea how an engine worked, he had heard this so many times that he assumed it had to be correct. How could it be wrong when every car produced before 1980 was started this way?
Larry
Old 07-19-2020, 09:33 AM
RV74ME RV74ME is offline
Default My technique
FWIW...
Lyc IO-360 M1B, one slick, one Pmag.
Hot start technique.....
Boost pump....ON
Throttle.........WIDE OPEN
Mixture..........FULL RICH (2-3 SECONDS)
Mixture..........ICO
Throttle.........CLOSED
Boost pump...OFF
Throttle.........1/2 OPEN
Starter...........ENGAGE
Mixture..........SLOWLY ADVANCE AS IT BEGINS FIRING
Throttle..........REDUCE TO IDLE
This works for me every single time. YMMV
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7 slow build
AUO
Old 07-19-2020, 10:31 AM
Thnx Steve/All. Steve’s method sounds like the best path. The person who warned me against it had no maligned intent and is not, to the best of my knowledge, superstitious. Perhaps he is, like me, still trying to learn about non-cert aircraft’s idiosyncrasies.
Old 07-19-2020, 01:34 PM
flyinga flyinga is offline
Steve forgot to turn the mags on
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 07-19-2020, 04:08 PM
Bwaaaahaaaaa
Did that only last week for real - soon started when I switched them on. Super cool though, I was still cranking
Old Man Hatton noticed though - Doh !!!!!
Donated in 2020
