07-18-2020, 03:00 AM
Seeking reviews on SDS induction flanges
The Experimental SDS induction flanges have been on the market for a couple of years now. Can any of the early adopters provide some feedback on their experience with this product...good or bad.
I see that SDS sells this product with silicon o-rings and silicon hoses for fuel injected engines....and with viton o-rings and nitrile rubber hoses for carbed engines. Apparently the rationale is that the silicon doesn't like avgas too much. But fuel injected engines can have avgas in the induction tubes too...from engine priming. So why bother with the silicon components at all...is there any advantage at all to the silicon or is it just to cut costs. Maybe Ross could answer that.
Bob Barrow
RV7A
07-18-2020, 05:03 AM
Hey Bob,
Great product and a great upgrade from the normal "warped clamp, leaking gasket") syndrome that Lycoming has as Standard kit.
Mine have been fitted for over 2 years and 250 hrs .
At the time, I did not upgrade the hoses so no data there.
https://vansairforce.com/community/s...161030&page=11
Post 102
07-18-2020, 05:28 AM
Hi Bob,
I also installed these flanges about two years ago with the silicon hoses. No complaints whatsoever, and my engine has never run so smooth!
Full write-up:
http://rvplane.com/?categoryid=10000&dayid=1392
07-18-2020, 05:46 AM
Upgrade
After I installed the product, my #2 cylinder went from being the hottest to the coldest.
I obviously had an induction leak. Recommend the product. SDS makes nice products with great machining.
Al Girard, Newport, RI
N339AG
RV-9
07-18-2020, 07:50 AM
As I installed/proofed the prototype kit, I'm by default the leader in installed calendar time. I have no issues that Im aware of. I had one tube off a few months ago and the flange O ring (silicone) was perfect. The same one went back in.
I think Ross is 100% viton now, but you could sure ask for it anyway if you like. The O rings may be life limited someday, but they are by far the least expensive parts of the kit and super easy to change if ever needed. The kit is essentially an "install and forget" deal.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
07-18-2020, 08:46 AM
Just got finished returning my 9 to service after installing a new B&C Alternator and a set of SDS flanges, hoses and O-rings. Took about an hour to replace and re-install. It is smoother and I am convinced it’s a better system. Good outfit to deal with.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
07-18-2020, 08:55 AM
We only supply silicone O-rings and hoses for EFI applications where there is really no fuel present in the induction tubes. We found with the mechanical injection, fuel still seeps down there after shutdown and could swell the silicone O-ring, making re-installation difficult if they were removed.
All carbed engines get Viton/ Nitrile bits.
95% of what we supply now are with Viton O-rings with Nitrile hoses.
Mike Robinson came up with this design so this wasn't my brainchild. Thanks again Mike, it was a great idea.
One engine building shop is now using these on every engine that goes out. We've sold many hundreds to date. Only one set returned so far, where the buyer didn't think the design was safe and never installed them. Experience has shown them to be totally safe.
We normally stock clear, gold and red. Can do black and Navy blue if you're not in a rush.
07-18-2020, 12:31 PM
I have Ross' induction flange kit on my angle-valve engine. Installation required cutting and re-welding the induction tubes. Clint at Vetterman exhaust did that work for a very reasonable price.
It has been a bit over a year. No troubles or issues, engine humming along smoothly.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
07-18-2020, 03:07 PM
RV-9A/ O-320
I installed Ross' no-leak induction on my RV-9A/ O-320 at this year's condition inspection. I also replaced the oil return lines with new line and constant tension spring clamps. Both are relatively simple, especially Ross' kit.
I'd do it again in a heartbeat and will on my RV-10/ IO-540 when the time comes.
Eric Rushing
RV-10
90% done, 90% to go.
Looks like an airplane!
Molalla, OR
