  #21
Old 07-15-2020, 10:38 AM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Originally Posted by tracy View Post
Chris, I eliminated that problem with Increased To .090 Thickness, 2024 Aluminum With 45 Degree Linear Brace From Carb To Front Of Air Box (no more mount cracks)
Thanks Tracy. I was going to increase the thickness of the aluminum when I realized it was already .064 and figured if that is going to crack then anything might. But I'll give that a try next time, especially the "brace" -- that's probably the key, like the one I use to stabilize the engine baffles near the oil cooler.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 07-15-2020, 11:43 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Chris
The brace does appear to work Chris - I have them on all of our planes, and once installed, we haven’t had a cracked plate since.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-15-2020, 12:47 PM
David Carter David Carter is offline
I just fabricated & installed a 0.063 top plate as part of my AFP injection conversion. The original plate had a large crack in it. Sounds like I now need to add that brace. Does anyone have a picture? I'm a visual learner.
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
Old 07-15-2020, 01:24 PM
Ces 140 Ces 140 is offline
No way that was caused between inspections There I said it sorry
RV 7 test flight summer 19!
1948 C-140 Flying By us for 14yrs
Dues PD for 2019 Jeff
Old 07-15-2020, 02:15 PM
Ralph Inkster Ralph Inkster is offline
Oh, yes it can. I watched an owner remove a filter, clean & re-oil it and put it all back together. 2 months later after a major trip, he came in for an oil change & found his filter trying to escape, not near as severe as OP's example, but if given a few more hours would have been as ugly. The owner commented after the fact that there was a ring groove in the bottom of the FAB but didn't connect it's importance.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 07-19-2020, 12:27 PM
tracy tracy is offline
https://vansairforce.net/community/a...1&d=1595182272
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
