Old 07-09-2020, 09:48 PM
oren_rokach oren_rokach is offline
Default Access panels
(following a thread on FB)
How many of you already installed the front of windshield access panels?
what did you use for sealing to avoid leaks?
How many are against and why?
Oren Rokach
4X-ODU
RV-10 QB
Cabin top installed, doors completed!
Wings almost done
Blog:
https://4x-odu.blogspot.com/
VAF 2020 dues paid!
Old 07-10-2020, 04:32 AM
Auburntsts's Avatar
IMO they simply aren't needed. In this day in age of multiple EFIS screens, if you remove one you've got a big hole to get to stuff. I have the stock panel that's one-piece (vs the segmented version in the plans) with no special attachment (ie hinges, etc) and I've haven't had any issues. YMMV....
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 07-10-2020, 05:22 AM
Dennis Harm Dennis Harm is offline
Default Access panel?s
Installed access panels in my 14 A . Just the ability to work from the outside I worth it IMHO. Sealed with a thin bead of fire barrier 2000.
Old 07-10-2020, 06:14 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default I installed access panels on my -6A and seal them with
silicon "grease" --- scuba shops have it, or on Amazon. Works good and easy to clean off when needed. I use my panels frequently for work and inspections. Could not maintain the plane without them.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-10-2020, 06:22 AM
Auburntsts's Avatar
Ron
Really? That seems to be a bit of an extreme position but I don't know your planes. I just completed my 6th condition inspection on my 10 and there's nothing that front of windshield access panels would have helped make the inspection any easier or better, and definitely nothing that would have helped maintain the plane over these past 5 years. Having said that, I see nothing wrong with adding these panels but I just don't see the point.
PP ASEL-IA
WAR EAGLE!
Old 07-10-2020, 07:22 AM
Default As always...
As always, what's good for one build may not be good for another.
I installed the access panels and could not be happier. If I had put them in sooner, I would have been able to use the space between the sub panel and firewall for placement of some of the LRUs, instead of trying to cram them all on the sub panel.
I will be using closed cell, self adhesive silicone foam weather-stripping for a seal. Available at McMaster...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 07-10-2020, 07:31 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Installed on my -14A
I have a QB fuselage - I am still in the build process - however i installed these as one of the first items i worked on with my QB. They have allowed me to do lots of work MUCH easier. Installation of rudder pedals, installation of brake lines, fuel lines, firewall penetrations, etc. For me these were a great addition. I will also appreciate them as I install and maintain remote LRU's, etc. Very happy i did this - no more laying on my back as i did for years with my -9A tip-up! Check this out.
https://drive.google.com/file/d/1RUp...2eOQIw1zRaLwvy
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 07-10-2020, 07:43 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
I'm finding that the most needed hypothetical access panels would be in the glare shield, for access to the pilot (aft) side of the sub-panel from above. Will never happen of course - windscreen is in the way of any useful access from that angle.
I have access from below (by assuming the most painful sustained body position ever devised) and through the giant holes for the EFIS screens, so no real room for complaint.
The space between firewall and sub-panel on my build contains the FW ground block forest-of-tabs, the Dynon engine monitor module, the MAP sensor, SDS CPi2 controller boards and a harness connecting some left and right side avionics. Not much anticipated need to reach back there for routine stuff. The pilot side of the sub panel is easy access through the instrument holes except for the basket-of-snakes cabling coming out of the Advanced Control Module with some over-generous (IMO) service loop excess. The cables themselves really fend off any attempt to get to the Dsub retaining thumbscrews!
The most difficult access in the whole panel is typically trying to work behind the AeroSport 310 center stack with the carbon fiber tunnel covers installed. These side covers also house the alternate intake air and the parking brake Bowden cables, which I had the fortunate foresight to make separately removable from the panels.
Takes a contortionist with two wrists on each arm to hook up the GPS navigator tray connections.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 07-10-2020, 07:54 AM
lr172 lr172 is offline
I was able to get everything aft of the sub-panel and saw no need for an access panel. Plane looks much cleaner without it IMO. I just can't think of any reason that I would need it. I might think differently if I put a bunch of equipment up there, but with carefull planning, that shouldn't be necessary. My center stack avionics trays were done in such a way that they slide forward with the panel (have a service loop in the wiring), so also no need to get into that area for them either.
after owning a 6 for several years, I wanted a plane that would be dry when flying through rain.
Larry
Old 07-10-2020, 08:19 AM
9GT's Avatar
9GT 9GT is offline
There is a lot of room IP forward in the RV-10. I found it fairly easy to get to things behind the panel through the glass panel openings. Not so much on my RV-9A so I am still contemplating whether or not to install them. I do not like the idea of looking at them.
David C.
Howell, MI
