07-08-2020, 08:43 AM
Alternator advice please
I currently (no pun intended) have a B&C SD-8 alternator attached to the vacuum port of an O290-D2 in my RV3. It?s minimal output just isn?t up to the task anymore, so I?m looking for a replacement in the 20-30A range. I?m considering the B&C 410-H (plus external voltage regulator) and the Plane-Power FS1-14B (built-in voltage regulator). My battery is an Odyssey PC680 which I may also replace.
Does anyone have any experience with either of these alternators that they care to share? Does anyone have any alternative suggestions for alternator and/or battery combinations? I?m just trying to keep it light and keep it simple.
Many thanks for any suggestions.
RV-3A (C-FARV) bought
RV-8 building
A330 borrow
Donated 2020
07-08-2020, 09:06 AM
I use the 410-H
as my backup on my -6A --- I often "test" the system by turning off my primary and motor along on the backup. My system usually pulls about 18-22 amps with everything on. The 410-H keeps up well. I have it set to put out about 13.8 volts.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
07-08-2020, 09:45 AM
I have a 410H and Sorial battery in my 8 but only 21 hrs, so far good. Lights are LED and the rest doesn?t pull many amps. No alternator running off the flywheel.
07-08-2020, 11:20 AM
B&C
I have been flying with the 410H for 10 years. No problems! 550 Continental has a better drive ratio - I can get useful power around 850RPM. The LYC system might need closer to 1000RPM to make useful power?
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
07-08-2020, 11:52 AM
I now have 70 hrs on a 410-H alternator on my RV-4 0-320. I have the regulator mounted on the cockpit side of firewall with a blast tube directed on the Alternator. My battery is a RG series Concorde. I've had no issues or problems. Takes about 1K RPM to extinguish the low voltage light. I have steam gauges except electric tach and electric CHT/EGT, transponder, single comm, backup electric fuel pump, and I-Fly 740b hard wired. I do not have ADSB out, only IN through the 740-b. Steve
07-08-2020, 12:56 PM
Autozone 14184
Externally regulated 35a was $20 at autuzone with lifetime warranty. First one lasted 8 years and 500+. hrs and they gave me another one for nothing. Regulator was from eBay for another $15 or so from a 60?s era Ford IIRC. Good luck with whatever you pick.
Jim Woolard C56
N9855J RV-6 Donated 2020
07-08-2020, 02:55 PM
Super Moderator
Both of them are good choices. The advantage to the B&C is that it has an external regulator that is adjustable. You can set the standby voltage just a little lower than your main alternator and then the standby alternator will come on automatically if/when the main alternator fails.
Vic
 Vic Syracuse
www.Baselegaviation.com
07-17-2020, 08:36 PM
I'm about to install a B&C 410H alternator as my back-up. I'll be using the SB1B-14 external voltage regulator. The installation manual offers a choice of using a 40A CB or a current limiter for output protection.
Questions:1) What does ANL mean?
2) Why would I want a CB or a Current limiter? Pros/Cons of each? I know CBs are resettable vs the current limiter is like a fuse; one time overload. Other than that I don't know any more, but sure would like to.
George
Reason: comment
