Tom, one of the fittings on my pump had a flare on one end and a flare with the o ring boss on the other end - nice!
Bobby, yes, the folks at this very small municipal field always come out to pump and they noticed it. I would probably have caught it as it takes a minute or so for the fuel in the system to back flow through the leak. It also is enough to leave a significant puddle.
I had always thought that a pump diaphragm failure would cause a small relatively insignificant leak. In this case the leak was estimated to be a gallon in four minutes at 1400 rpm during a subsequent ground run up. Needless to say, that was un-sat for further flight even though the pump was still making 25 psi!!
This happened at the end of a 2.5 hr cross country. Not sure when it started or how fast it leaked in flight, but I estimate 1.5 gallons were lost in flight using totalizer data. Engine never missed a beat.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
