Go Back   VAF Forums > The Never Ending Debate Section > Tools
  #11
Old 06-02-2020, 03:41 PM
mike newall's Avatar
mike newall mike newall is offline
Numatx,
2 pressure settings, 1 for -3, 1 for -4.
No shims
Yokes interchangeable
Super lightweight head and an extra pair of hands as your foot actuates the squeeze.
Also, for long rivets you are not, off the cam like a normal air squeezer is.
Yes, more expensive, but you will always sell for top dollar when your project is done.
https://www.youtube.com/watch?v=mcFAgD5yabk
https://www.flyboyaccessories.com/product-p/2701.htm
Oh, junk the yellow thing - we are all grown ups and don't need nannying
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 06-02-2020, 06:00 PM
rockitdoc's Avatar
rockitdoc rockitdoc is offline
Originally Posted by mike newall View Post
Numatx,
No shims
Yes, but are die sets interchangeable with hand riveters like Main Squeeze?
Old 06-02-2020, 09:47 PM
DanNiendorff DanNiendorff is offline
The Numatx and most pneumatic squeezers use a CP214 style yoke. Cleveland website says main squeeze uses the same.....
Add my vote for quick change pins.
The Cleveland dies (and others) will fit in these yokes.
RV-14A 140658 Empennage in progress
Zenith CH801 - old school pre-CNC era kit - flying
Zenair 2500A amphib floats - From basic parts kit - 80%
Dues 2020 ✅
Old 06-03-2020, 04:53 AM
Donated in 2020
Old 06-03-2020, 07:44 AM
Don't worry about the weight. You'll get used to it pretty quickly.
There are just a very few -6 rivets, less than ten. They are used for filling tooling holes in specific places. A normal pneumatic squeezer like my CP-214 can set them but you should expect to have to make multiple squeezes to do it. It's not a big deal. Also, while they are universal head rivets, you can use a flat set on them - it's approved per that Mil-Spec for riveting that's on Van's site. You don't need to buy a special set just for those.
Wirejock, remember I mailed you a few?
Dave
Old 06-03-2020, 08:22 AM
wirejock's Avatar
wirejock wirejock is offline
Default #6 Rivets
Originally Posted by David Paule View Post
<snip>
Dave
Yes, monsters! I used two to fill the tooling hole in each inboard fuel tank rib. Had to set them using the gun on a bar clamped in the vise.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-03-2020, 09:35 AM
Yeah, that's where they go, at least on the single-digit kits. And perhaps I used a gun, too.... it's been a while.
Dave
Old 06-29-2020, 08:19 AM
FlyGuy65 FlyGuy65 is offline
If you decide on the Numatx, get the upgraded hose. Flyboys has an option to buy it that way, or you can buy the hose after the fact from TSFlightlines. The standard hose is larger, stiffer, heavier. Upgrade is a smaller metal braided hose, well worth the $$$.
