Razor technique
Thats totally fixable. Sorry, I hadn't looked at the photo. Dan's razor method works really well. You need plenty of light so you can see when the drip has been removed down to the level of the flat surface. I have found the razor needs to be retreated when it stops scraping.
Once you remove the drip, follow his compound and polish method. Tape over the rivets to prevent blowing through the paint.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
