Old 06-13-2020, 08:53 AM
airshawn58 airshawn58 is offline
Question Fuel pressure indicator pegged
I tried to fly my RV 7A yesterday, but after run-up, the fuel psi gauge on my Dynon EMS-120 read 57.2. I tried leaning, full power, idle, mags on-off; gauge still pegged. I?m not a mechanic, A/P or the unit?s installer. I would welcome any advice, but please dumb it way down.
Old 06-13-2020, 09:02 AM
Ron B. Ron B. is offline
Carbureted or Fuel injected? Sorry I just saw it on your other post.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 06-13-2020, 09:05 AM
Are you sure you have the correct range sensor installed for your Dynon and have you gone into the setup menu and selected the correct sensor? And check your grounds on your sensor.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 06-13-2020, 09:54 AM
Ron, I have not explored sensor menu items, but the plane has been flown for hundreds of hours with this EMS unit always indicating expected value of 30psi.
Old 06-13-2020, 10:24 AM
DavidAhrens DavidAhrens is offline
Default fuel pressure high
Hi there, Is the reading pegged out with engine and fuel pump not running? If so, you probably have a sensor or wiring problem. Their are other checks you can do to determine the problem but they require that you know a little about the electrical operation of your setup.
Old 06-13-2020, 10:35 AM
lr172 lr172 is offline
assuming it is a VDO sensor (the kavlico's weren't available when the 120 was being sold), the most likely reason is a failed sensor. They often don't make it anywhere near TBO and usually fail by reading high.
Larry
Old 06-13-2020, 12:31 PM
Carl Froehlich's Avatar
Had the same problem at first engine start. Used an analog gauge to verify the pressure was correct. Reconnected the fuel pressure sender and it worked perfectly.
30 hours and no recurrence. Perhaps it just needed to be exercised.
But - they do go bad. May be time to buy the new replacement sender from Dynon.
Carl
Old 06-13-2020, 12:34 PM
TS Flightlines TS Flightlines is online now
VERY likely a bad sender---but also check the electrical ground.
Tom
Ridgeland, SC
Old 06-13-2020, 04:38 PM
RV7A Flyer's Avatar
Fuel pressure is not required for VFR flight...
2019 Dues paid!
Old 06-13-2020, 05:28 PM
You will need a tow plane!!!!
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
