Old 10-19-2017, 10:16 PM
mfleming's Avatar
mfleming mfleming is offline
Default Completed Initial Leak Test of The Left Tank
Initial test of the left fuel tank has passed.
The Float access plate was tested with the cork gasket installed. Now that the initial test was a success, I'll pull the plate, remove the cork gasket, pro seal up the plate, reinstall and retest.
The multimeter is measuring ambient temperature for a reference as I recorded pressures during the test.
During the test I used a leak test fluid to check all the seams and rivets.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 10-19-2017, 10:22 PM
jcarne's Avatar
jcarne jcarne is offline
I'm keeping my fingers crossed for you. I'll be right behind you, I'll probably get to that in a couple of weeks.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 10-20-2017, 12:23 AM
Tag Tag is offline
Lots of luck! My RV8 tanks are being tested now also. So far, so good....
Old 10-20-2017, 12:32 AM
Beancounter Beancounter is offline
I will keep my fingers crossed for you too, that the cork gasket wont turn to goo like mine did.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 10-20-2017, 09:53 PM
mfleming's Avatar
Thumbs up
Van's and Synergy recommend eliminating the cork gasket and just using sealer now.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 10-20-2017, 09:57 PM
mfleming's Avatar
Smile Second Tank Passed
Completed my initial leak check on my second tank today...Passed.
Tomorrow I'll seal up the end plates, let them cure for a couple of days and then do a final leak check on the tanks.
Using leak detection fluid to track down any leaks.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 10-21-2017, 09:03 AM
jcarne's Avatar
Great news!
Jereme Carne
PPL
Old 10-23-2017, 01:21 PM
Draker's Avatar
Draker Draker is offline
Did Van's post anything publicly to that effect? I'm getting close to closing my tanks up and am still going back and forth on "cork + Permatex" vs "cork + Proseal" vs. just Proseal.
Old 10-23-2017, 05:17 PM
RV74ME RV74ME is offline
When i took the factory tour, the guy there told me to toss the cork gasket as far as i could!!
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7, Lyc IO360
AUO
Old 06-11-2020, 11:52 AM
mfleming's Avatar
Wink For The Historical Record
I realized that I never really finished this thread.
So after both tanks passing the initial leak test I removed the cork gaskets and installed the plates with just pro seal.
After letting the tanks cure for at least two weeks, I retested using the same procedure. Both tanks passed the leak tests.
Procedure used for testing tanks:
  1. Closed or sealed up all tank openings
  2. Installed a 0 to 15 inches of water pressure gauge on the tank drain fitting.
  3. Set up a temp probe next to the tank.
  4. Pressured up tank to 9 inches of water.
  5. Recorded the pressure and temperature every 30 minutes to an hour for over 12 hours.
  6. Used leak test fluid periodically to look for leaks. (SNOOP or equivalent)
  7. Let sit overnight, continued recording temp and pressure for another 12 hrs.
  8. Ended test
The pressure / temp recording allowed me to track the pressure movements (and they will move) during the 24 hr test. The method for making sense of the pressure fluctuations is:
Pressure fall and temp falls = normal contraction of air volume.
Pressure rises and temp rises = normal expansion of air volume.
Pressure falls and temp stays the same or rises = possible leak
Pressure stays the same and temps rise = possible leak
Pressure increases and the temp falls = laws of physics ceased working
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
