Old 06-04-2020, 06:40 PM
Jskyking Jskyking is offline
Default AN470 AD 6-5 rivet/ tank rib sub assembly
The plans below call for a 6-5 rivet though the kit only includes 6-6?s. My first attempt at setting this rivet was with the DDRT dimpler. The first rivet set went good, the second was a disaster. The plans call for using a C-frame, that might have helped had I owned one.
As I understand, this large rivet is only there to fill a hole and requires only enough squeezing ? to retain the rivet in the hole?.
I presume that to mean as long as the rivet doesn?t turn and doesn?t fall out it?s good to go.
Anyhow- is there an effective method to facilitate setting this large rivet without a c-frame?
In lieu of no other direction, My plan tomorrow is to put a slight squeeze on the rivet with my DDRT or tap it with a bucking gun and rivet set, if I have one large enough to fit this big honking rivet.
RV14 Empenage complete
Wings in work
Dues bypass eligible- paid anyhow
Old 06-05-2020, 05:42 AM
RV6-KPTW RV6-KPTW is offline
I set those with rivet gun / bucking bar.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/30/2019 * 2
Old 06-05-2020, 05:47 AM
Mark Browning Mark Browning is offline
This can be achieved with the correct size set and a Yoke in the hand squeezer.
The pneumatic squeezer struggles to set AD6's
It will take a few squeezes and adjustments to get it to set
Remember to use a bit of pro seal under the rivet head
Old 06-05-2020, 06:59 AM
Two very good ideas. I may try both methods.
Thanks.jt
Wings in work
Old 06-05-2020, 08:29 AM
jacoby jacoby is offline
FWIW, on my -10, a local builder gave me some 470A-6-? (soft) rivets that I cut down to the -5 length. They set easily and quickly with the gun. -6 length is too long since you are just going through the one skin. I would trim one to -5 length if possible, especially since you are using AD rivets, and see how it set. 1/16" makes a pretty big difference.
And, yeah, you are just trying to fill the tooling holes.
Old 06-05-2020, 09:11 AM
wirejock's Avatar
wirejock wirejock is offline
Default #6 rivet
I put my bar in the vise so the base was firmly planted on the vise frame. Set the rivet with a gun. It just filling the tooling hole. As long as it doesn't rattle, slop some proseal over it and call it good.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-05-2020, 09:21 AM
tyconnell's Avatar
tyconnell tyconnell is offline
Can a cherry max be used here?
Ty Connell
ty.connell@gmail.com
Donated 2020
Old 06-05-2020, 10:51 AM
wirejock's Avatar
Default Pop rivet
No need for a structural rivet. It's just plugging a tooling hole. Find a pop rivet the right size. I recommend the factory head on the inside of the tank.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-05-2020, 11:07 AM
engineerorange engineerorange is offline
Default another option
I riveted a square patch over the hole when I built my tanks, didn't have any 470-6 rivets.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
Old 06-05-2020, 02:24 PM
kbalch's Avatar
kbalch kbalch is offline
I set those with a rivet gun in the C-frame. Easy-peasy.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
