Old 05-25-2020, 09:28 AM
E. D. Eliot E. D. Eliot is offline
Default Got my new elevatir trim servo
Decided to just replace my new -not yet installed trim servo and after contacting them, sent it in to Ray Allen Co. last Monday. Got the new modal last Friday. The new one is a little 'fatter' and mine, at least, required some trimming of the hold down pieces on top # 1287. Not a problem, just wanted to let you all know.
Thanks to the Ray Allen Company for the reduced price and the quick delivery of the new servo.
Building finally
Old 05-25-2020, 10:14 PM
rcarsey rcarsey is offline
sounds good. I'm going to replace mine too at this point (pre-AW inspection).. The loss of trim in flight is something I'd like to avoid.. an for $100, I'll just do it now and get it over with rather than have that in the back of my mind...
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Tail 100% done
Wings 95% done (AOA)
Fuse 100% done
Finish 100% done (cowl)
Avionics 100% done
Dues paid 2019
Old 05-25-2020, 11:01 PM
Hey E.D., I'm looking at the updated Section 11 and it appears as if those hold down pieces are no longer required.
https://www.vansaircraft.com/wp-cont...1iS-U_12iS.pdf
Is the base of the trim motor now made of metal? I think those hold down pieces were necessary because (i believe) the base used to be plastic.
RV-12iS (N713)
Tail 100% done
Fuse 100% done
Avionics 100% done
Dues paid 2019
Old 05-25-2020, 11:12 PM
pilotyoung pilotyoung is offline
Default Got my new elevator trim servo
I got mine Friday. I did not read the Safety Directive clearly. I thought the bushing would come with the trim motor. It did not. So I called Van's and read the Safety Directive and I ordered the bushing, and new tray from Van's for the complete new installation. I also ordered the new electrical connectors. My aircraft is serial number 120022 so I new I needed new parts. As soon as the parts from Van's arrive, I will install all of them. I told to send the parts the cheapest way so it may be next week before I receive them.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 240 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 05-26-2020, 10:38 AM
Default Reply to Rob
The whole case of the new servo appears to be a high grade plastic - almost like bakelite like. I will use my modified aluminum hold down pieces anyway as they distribute the holding force well.
Also, if I were you I'd install the servo with the six hold down screws that are used in the older servo installation - match drill the two holes in the center of the bottom plate. Hope that that makes sense. Not second guessing Van's engineers here just like the original plans set.
Building finally
Old 05-27-2020, 01:02 PM
Sclookout Sclookout is offline
Thanks for the heads up John. I also assumed the replacement servo included the bushing.
