Old 05-27-2020, 02:47 AM
JohnD.TF4 JohnD.TF4 is offline
Default Clear Fuel Line / Fittings
Greetings all,
I am designing a ferry tank and would like to install a visual fuel gauge like the one depicted below using a transparent fuel line to get a live view of what is going on in the tank.
Does anyone know what kind of aviation grade clear fuel line and appropriate fittings I should be looking at?
Thanks!
https://lh3.googleusercontent.com/pw...-no?authuser=0
John D
RV-12(ULS) Pilot,
wannabe RV-8 Builder,
General Purpose Airplane Nut, etc,.
Old 05-27-2020, 04:45 AM
h&jeuropa h&jeuropa is offline
Hi John,
We have a similar sight gauge in our Europa. Over the years we have tried several different hoses. What works best is Tygon SE200. This is a clear hose with a teflon liner. You must be careful not to bend it sharply as the liner will kink. In our setup we have SE200 inside generic clear hose to provide support. This setup has been in place for over 5 years with gasoline in contact 24/7 and shows no discoloration.
Tygon 4040 is listed as being for fuel lines. It is the common yellow hose often seen in marine applications. Our experience is that it hardens after a few months. It does work well as vent hose. Gasoline vapor doesn't seem to affect it and it doesn't kink like SE200.
Jim Butcher
Old 05-27-2020, 06:46 AM
What fittings do you use with that hose?
Thanks!
John D
RV-12(ULS) Pilot,
Old 05-27-2020, 06:53 AM
snopercod's Avatar
snopercod snopercod is online now
I have a sight glass permanently installed in my panel. It uses "Superthane" tubing from U.S. Plastics. https://www.usplastic.com/catalog/it...x?itemid=66293 To make the level easier to see, I added a red plastic ball as used on Piper aircraft. https://www.univair.com/piper/piper-...ge-float-ball/ If you use one of those balls, be sure to make sure it can't pass through the fittings and get into the tank itself.
(2020 dues paid)
Old 05-27-2020, 07:37 AM
Find a Grumman TR2/AA1B that Is salvageable and get the fuel tank sight tubes from that. Call Roscoe at:
Yankee-Aviation.com
I?m sure he can help. He has every part ever made for a Grumman.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 05-27-2020, 07:54 AM
Radioflyer Radioflyer is offline
John D. I was wondering why a ferry tank, for which model, for extended range?
Old 05-27-2020, 08:04 AM
John, since its going on a ferry tank that probably wont be installed permanently, it isnt a big deal. BUT---I would test whatever clear hose you decide to use with the actual fuels you'll be using.
Because we dont know all the chemicals in the different fuels, at least I dont, we dont know how some hose material may react to the fuels. Since you'll probably be removing the tank, its easy enough to replace the hose every so often.
But --it might take time for the hose to react to the fuels.
Had a client in AZ that had a beautiful high wing plane with some "supposed fuel resistant" hose. Hoses from the wings to the selector valve were hidden by closeout panels. After being gone for a while, they discovered the fuel had eaten through the hose and leaked fuel all over the cabin and interior pieces. Needless to say it was a heartbreaking and expensive repair.
Tom
Ridgeland, SC
