  #91
Old 05-26-2020, 08:51 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by PhatRV View Post
I just received the new NAS bolts that are long enough for the higher strength nut.
In the picture below, the NAS6206-27 bolt and the shallow nut are from Van's RV8 kit. This bolt it turns out has a shallow thread depth which is designed for the shallow nut. The NAS6606-27 on the right has the standard thread depth which allows extra threaded length for the NAS1804-6 nut or other standard sized nut. Both of these bolts have the same un-threaded shank size, and the same diameter.
Awesome. I understand that these bolts are just the four outboard gear bolts that go through the U803 saddles and I need to torque them to 240 in/lbs but Aircraft Spruce doesn't have either one of them (unless the nut is NAS1804-6N and they add an N to the end, if it's the same one) and that's on backorder until next month. Where did you order them from?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 05-26-2020, 09:34 PM
skylor's Avatar
skylor skylor is online now
Default Genuine Aircraft Hardware Co
Try Genuine Aircraft Hardware Co.
Skylor
Old 05-26-2020, 10:20 PM
PhatRV PhatRV is offline
I ordered them from https://military-fasteners.com. Aircraft Spruce doesn't carry this size and the order person there refused to make special order. Bummer.
Unfortunately, the military-fasterner only sells in a pack of 10 bolts. After I install 4 bolts, I have 6 left. Let me know if you want the rest or a partial. Send me a PM.
Phat Vu
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
Old 05-26-2020, 11:47 PM
scsmith scsmith is offline
Thanks for posting this picture and description. It is a great addition to the thread (ooh! is that a good pun?) to help people get the right bolts.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 05-27-2020, 04:21 AM
74-07 74-07 is offline
Default PHAT RV
Please check your PM
Old 05-27-2020, 11:24 AM
Pilot135pd's Avatar
Phat Vu
Thank you very much for the generous offer, yes I'll take 4 sets.
Old 05-27-2020, 01:29 PM
Pilot135pd's Avatar
Is there any other difference between the NAS1804-6 and the NAS1804-6N that Aircraft Spruce sells? The only thing I found in the description on Military Fasteners is the N is "non dry film lube"
https://military-fasteners.com/nuts/...uts/NAS1804-6N
while the one without the N says "dry film lube"
https://military-fasteners.com/nuts/...nuts/NAS1804-6
Everything mentioned on this thread is the part model without the N.
Old 05-27-2020, 01:54 PM
This is the one I ordered from ACSpruce
https://www.aircraftspruce.com/catal...6n04-03822.php
Wing -- Closed
Old 05-27-2020, 05:12 PM
Northernliving Northernliving is offline
Any if you are using Grove gear, you need a NAS6206-36 bolt to work with the NAS1804-6 nut. I may have some extras if someone needs them.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 05-27-2020, 05:15 PM
Pilot135pd's Avatar
Please tell me the Grove gear was an option and not part of the kit back in 2007ish !
How do I know if I have a factory gear or a Grove? I just ordered the bolts and nuts everybody said here and now this wrench in the system. I checked the Grove webiste and they don;t show a landing gear for any Van's aircraft. Now I'm really confused. https://www.groveaircraft.com/aircraft.html
