Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #31
Old 05-26-2020, 09:17 AM
Romeo Victor Romeo Victor is offline
Thank you Don!!!
Best Regards
Stephan
Old 05-26-2020, 09:18 AM
Originally Posted by Don Jones View Post
Stephan,
The 50, 75, and 150 psi sensors (whether oil or fuel) are being replaced with the new style 150 PSI P255-150G-E4A. The 15 PSI sensor used by most carbureted sensors is being replaced by a new style 15 PSI sensor P255A-15G-E4A.
Thank you Don!!!
Best Regards
Stephan
Old 07-21-2020, 07:03 PM
Ron B. Ron B. is offline
Just replaced my Fuel and oil sensors. The original oil sensor was a 150 pis sensor so my oil pressure seems to be reading correctly. My fuel pressure sensor was a 50 psi sensor and the new one is a 150 psi sensor and my fuel pressure is reading 8 psi and in red whereas it should read 29 psi. I upgraded my software version from 15.3.3 to todays latest 15.4.7 and no change.
I would like to know how to change my sensor data from the 50 psi model to the new 150 psi model so my fuel pressure reading would be correct. I thought with the new software I would have the new sensor option available but I cannot find it.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 07-21-2020, 07:30 PM
pilotkms's Avatar
pilotkms pilotkms is online now
Search may not be working. Posted this a while back in “Safety concern with fuel pressure sender” :
I installed my 2 New sensors today - SKYVIEW. No changes to anything and my fuel pressure read 1/3 of Normal. Normal is 27, it read 9. Had to go into SETUP and select the new sensor in MAPPING. Now reads 27 as before.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 07-22-2020, 04:29 AM
I will look for MAPPING, Thanks
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 07-22-2020, 06:48 AM
flion's Avatar
flion flion is offline
Lucky for me, the G3X works with the VDO senders that were installed with the Blue Mountain EFIS that I was replacing. However, the BMA system read MAP from the ignition box(es) so I had to plumb for the low pressure sender, which failed out of the box. No leak, but never wavers from 32.2, which is impossible here at 7000'. Reads the same even if disconnected from the line and exposed to ambient pressure. Aerotronics (class act) are helping me out with a replacement swap but I have to say I am not impressed by this entire line of senders.
EAA Technical Counselor #5357
Old 07-22-2020, 07:09 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
In my case I have VDO sensors connected to my DYNON system. It has been this way since 2013 without any problems. YMMV
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 07-22-2020, 07:41 AM
Pdtofly Pdtofly is offline
Default The new Kavlico sensors
Ron,
I also swapped out both fuel and oil pressure sensors with the new 150 psi versions in my plane, and I had to play around a bit to get my fuel pressure to read correctly.
One thing you also need to do it update the Engine Sensor Definitions updated 5/14/2020. It has the new definitions for the new Kavlico sensors. Go to Dynon System Software for your screen, go to the bottom as it is the last item, download and install.
I will be out at my hanger in awhile, and will take a few snapshots of my settings and will post them here this afternoon when I get home, so check back tonight as I am west coast time.
Brian
Old 07-22-2020, 08:00 AM
jcarne's Avatar
jcarne jcarne is offline
Where are you guys finding the new sensors, I can't find them in stock to save my life!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 07-22-2020, 08:58 AM
Ordered from Dynon a long time ago.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
