Old 05-25-2020, 02:33 PM
Tony M Tony M is offline
Default Two gps antennas
Has anyone ever put two GPS antenna is on an RV 12 IS? I have the issue of GPS 20A needs a GA 35 antenna and the Garmin G3X panels want a GA 56 antenna. I want to have touch display as back up GPS.
Or a better question can I just use GA57 antenna with both units with a splitter and that would also deal with xm that would be ideal?
Old 05-25-2020, 02:43 PM
bjdecker's Avatar
bjdecker bjdecker is offline
I don't have an RV-12, but I do have 3 GPS antennas in my RV-7; GA 35 for the GTN 650, GA 26 for the G3X Touch GDU 460, and GA 37 for the G3X Touch GDU 465.
No issues or interference noted.
Cheers!
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 05-25-2020, 03:37 PM
Without a very careful investigation, splitters should be avoided. (1) many antennas these days have a built-in amplifier. The receiver is looking for a specific signal level from the antenna, different boxes may have different requirements. (2) GPS signals are very weak, I wouldn't give up half the signal from a non-amplified antenna;(3) the amplifiers are powered by dc running up the coax. You'd need a splitter that didn't interfere with that, and could tolerate additional dc running up from the other receiver.
Old 05-25-2020, 05:43 PM
rongawer rongawer is offline
I have a GA 35 and GA 56 side-by-side with 6" separation on the tailcone just behind the turtle deck bulkhead of my -12. They work great there. You can see them in the first photo of the linked article.
RV-12 build article
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 05-25-2020, 07:59 PM
Smile
Thanks everyone for the replies. And so that?s the new plan to use both.
