Old 05-23-2020, 06:34 PM
dbaflyer dbaflyer is offline
Default Backup alternator gasket
My alternator had a very small leak which looked like it was coming from the lower inboard side so I pulled it off and ordered a new gasket.
My alternator (B&C) had red circles of material on each location of the gasket holes. In order to clean the surface good, I had to remove all of those. What purpose would those serve and are they required?
Pic 1
Pic 2
Pic 3
Sorry about the photo links. The [IMG] tag did not working in my post preview
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 05-23-2020, 08:31 PM
rapid_ascent rapid_ascent is offline
I suspect the original gasket was installed with some gasket sealant and that is what the red circles are.
When I installed mine I used the sealant recommended by B&C on both sides of the gasket prior to installation.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-23-2020, 09:06 PM
airtractor8 airtractor8 is offline
There shouldn't be any oil in that area to leak past the gasket. The oil seal on the drive shaft must be leaking and that is not good for the alternator drive coupling. It is a shear coupling and is not supposed to run in oil. You may need to give some thought to changing the oil seal as well as the gasket.
Old 05-23-2020, 09:23 PM
I believe the oil is coming from the hole that would normally be used for a wet vacuum pump. See this photo in the bottom right corner. The bearing seal looks Ok.
Drive gear bearing
RV-9
