Old 05-23-2020, 09:37 AM
TheBebo TheBebo is offline
Default Wheel Pants
Hey Everyone,
Recently picked up an RV3B. LOVING it.
I have the dreaded shimmy. Tires are pretty far out of round/balance. Brakes are worn. I have a bit of work ahead of me. Thankfully the fear legs already have a wooden dampener.
Interestingly, without the wheel pants I have no shimmy at all. I have the "stock" wheel pants, they look... huge on this plane. The extra weight at the end of the gear can't be helping the shimmy, even if I replace brakes/tires.
What wheel pants are everyone else running on their 3's?
Dave E
Status:
RV-3B
RV-8 Tail 75% Complete
Builder: 83523
Old 05-23-2020, 10:31 AM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
I have an RV6 but I am running James wheel pants. I assume you also have 500X5 tires, so they would be the same for you. If you put on new tires and balance them it should help a lot.
RV6 N7219d
IO-320-B1A
Sam James cowl
first flight May 2, 1997
RV8 #83830 tail done, wing done
Fuselage started
Old 05-23-2020, 12:54 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Our -3 has standard pressure recovery pants, and they work fine. One thing that can affect shimmy is tire pressure - for us, lower pressure reduces it, higher pressure enhances it. Short of a major rebuild of....something..that is a quick way to reduce shimmy.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-23-2020, 02:48 PM
Been tinkering with lower vs higher pressure. 25psi seems to be the best place for my current setup.
New tires and tubes are going to be on order after the holiday for sure.
Dave E
Status:
RV-3B
Builder: 83523
Old 05-23-2020, 02:49 PM
Are the James wheel pants lighter? Narrower?
Dave E
Status:
RV-3B
Builder: 83523
Old 05-23-2020, 04:22 PM
They are narrower, not sure if they're lighter. I installed the James cowling so I bought a set of wheel pants to. When I got them it was Sam James and his son making them. The business got sold the new owners are still making them and the cowlings.
RV6 N7219d
IO-320-B1A
Sam James cowl
Fuselage started
Old 05-23-2020, 06:32 PM
yarddart yarddart is offline
Default Rv3b
At 35psi occasional shimmy 30 psi none
Old 05-23-2020, 08:58 PM
rv3pilot rv3pilot is offline
Is the shimmy dangerous? I have it as well but I just slow down and it stops. I wasn't going to worry about it. I don't notice it at all on takeoff, only on landings when I use the brakes to slow down. It only last for a couple of seconds when on the brakes. I then taxi with no issue.
Chris
Old 06-07-2020, 03:03 AM
Lufthans's Avatar
Lufthans Lufthans is offline
Just wondering - shimmy is nothing more than non-aerodynamic flutter. Our weapon against flutter typically is mass-balancing. Would the same work on wheel pants?
Hans Teijgeler
Hilversum, The Netherlands
Resurrecting an RV-3B
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
Old 06-07-2020, 08:15 AM
RWoodard's Avatar
RWoodard RWoodard is offline
My RV-3 has just a tad bit of shimmy as I decelerate to taxi speed. It only happens for a 5-7mph range between about 30 and 25-ish. Once I'm below this range, it goes away. I never noticed it on the takeoff roll... only on landing rollout.
My 3 is out of service getting an engine rebuild and I took the opportunity to have Allen at Anti-Splat do the main wheel bearing mod as well as mounting and balancing new tires and tubes. I did the bearing mod to get rid of the old fashioned trailer bearings, but if the shimmy ends up disappearing because of the balance job, that'll be a bonus.
I have the new style Vans pressure recovery wheelpants. The initial break-in flights for the new engine will be conducted without wheelpants to keep me from exceeding redline on the airframe. This may be a good opportunity to see if the wheelpants are contributing to the slight shimmy. It'll probably be several weeks before I'm flying again, but I'll try to report back with results. Of course there's a good chance that the AntiSplat work will eliminate all the shimmy (with or without wheel pants) so I may not have anything to report! :-)
My shimmy was never so bad as to be dangerous or really even annoying, but it was there.
Just another data point.
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
