Old 05-22-2020, 05:55 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Default Spinner for the Show Plane cowl
For those builders using the Show Plane cowl, where are you getting your 15? spinners and how much do they cost?
Carl
Old 05-22-2020, 08:17 PM
RandyAB RandyAB is offline
Carl
MT quoted $1700 for mine.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 05-22-2020, 08:31 PM
rongawer rongawer is offline
Whirlwind has 15" spinners. Although come with their props, they'd probably sell them separately if you call them.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 05-23-2020, 05:20 AM
KatanaPilot KatanaPilot is offline
Default Van's Aircraft/Hartzell Prop
Special ordered the Hartzell D-4798-1P polished spinner though Van's. $1540 plus shipping. You need to reach out to Barb at Van's if you want to special order this spinner.
The spinner that Van's shows on their website for the Hartzell three bladed composite prop is the C-4582-P. The D-4798 spinner is a bit longer and I like the aesthetics better.
I have the Show Planes cowl. I haven't installed it yet, but another RV-10 next to mine at Synergy Air South has the same cowl, the same prop and the unpainted version of the the D-4798 spinner installed. It looks really nice.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 05-23-2020, 08:16 AM
Thanks Krea.
On the first RV-10 I used the James cowl. I consider this cowl the best modification I did on that plane. Talking with the new owners of James Aircraft they are working to offer an RV-10 cowl again (and an RV-14 cowl) but no timeline in place. I?m looking at the Show Plane cowl as a backup plan.
The James Cowl uses a 14? spinner. At the time Hartzell wanted $1400 for a polished spinner. I found a kit plane place that uses the same spinner on their kits and got it for $750 (shipped direct from Hartzell so it gives you an idea on the markup).
For me, the stock Van?s cowl and 13? spinner is just out of proportion for the RV-10. The new plane will sport either a 14? or 15? spinner.
Carl
