Old 05-20-2020, 05:07 PM
FlyGuy65 FlyGuy65 is offline
Default Tank baffle sealant - how much?
Almost time to install the fuel tank baffle - looks to be a lot of sealant required! Anyone remember how much sealant they used at that step?
I started using the George O. method of 30ml white/3ml black, but that was too much sealant per rib (and I was too slow to do more than one rib at a time). Converted to weight - 20g/2g. Now looking at the baffle and trying to figure how much to mix, and if I have enough left.
Old 05-20-2020, 07:30 PM
GeoffP's Avatar
GeoffP GeoffP is offline
I think I mixed up 2 batches of around 35 / 40g for the baffles when I did my -9 tanks a few months ago.
RV-9, Tail Feathers done, Wings almost done.
Old 05-21-2020, 07:20 AM
1001001's Avatar
1001001 1001001 is offline
For the rear baffles on my -10 left hand tank, I used a total of about 300g of mixed sealant, if I recall correctly. I had a little left over, but not an excessive amount. This includes the recommended 3/16" bead on the long edges of the baffle, sealing each rib, a coat of sealant between the baffle and each z-bracket, globs in the corners, and a small dollop on the head of every exposed rivet.
The -10 tanks have about 240 linear inches of seams to seal, and about 314 rivets associated with the rear baffles/z-brackets, so adjust accordingly for smaller tanks?
Old 05-21-2020, 07:54 AM
wirejock's Avatar
wirejock wirejock is offline
Default Proseal
According to my blog I used 110 grams mixed per tank baffle.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-21-2020, 02:56 PM
Thanks. Too close for comfort, ordered more...
