Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 05-18-2020, 02:24 PM
TShort TShort is offline
Thanks Justin.
Do you have a link to purchase the new 75PSI sensor?
Does it use the same connector / wiring as the current equipment?
Do you recommend any change to the oil pressure sensor as well, or just the fuel system?
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 05-18-2020, 03:45 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Fuel Pressure Sensor Part Numbers
Originally Posted by TShort View Post
Thanks Justin.
Hi Thomas,
They do use the same wiring as the currently fielded sensors. You can purchase them through a Garmin Dealer using part number 011-04202-30 for the oil pressure sensor and part number 011-04202-20 for the fuel pressure sensor.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 05-18-2020, 07:56 PM
RV74ME RV74ME is offline
My fuel pressure rose to a max of 49.1psi within 5 minutes after shutdown. Lycoming IO-360.
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7 slow build
AUO
Old 05-19-2020, 07:41 AM
olyolson's Avatar
olyolson olyolson is offline
Default Kavlico sensor
I have the legacy sensors for oil & fuel pressure on my engine. Was concerned at first but no leaks since they were installed so I?m leaving them on for now. Advanced Flight Systems will have the new ones in stock in a week or so. I contacted Sansata Technologies in San Diego, the parent company. The new sensor should connect with the snap connectors on top to existing wiring harnesses.
From Sensata:
? This are using a Packard Metripack 150 connection, you should not have any issues connecting the new sensors with the existing harness.?
Regards
Aldo I. Vasquez
Field Application Engineer, North America ? Industrial Solutions
aldo.vasquez@sensata.com || 619-252-7664 mobile
Sensata Technologies, 2320 Paseo de las Americas, Suite 201, San Diego, California 92154
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 05-19-2020, 04:43 PM
Jpm757 Jpm757 is offline
Checked mine today (IO360 Avatar servo), immediately after shutdown fuel pressure went to 45psi. Pushed the mixture back in and it immediately dropped to near zero and stayed there. My new procedure AFTER shutdown will be to go full rich mixture, then ICO. Seems to solve the pressure spike issue. Only thing I can figure is that this is due to the Avstar servos NOT incorporating a fuel return line. Anybody see this fuel pressure spike with return line systems?
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 05-19-2020, 04:58 PM
Walt's Avatar
Walt Walt is offline
AFP system with purge valve, pull the purge valve, engine stops, pressure goes to '0' with no engine flooding.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-21-2020, 09:07 AM
Brantel's Avatar
Brantel Brantel is offline
Originally Posted by g3xpert View Post
Hi Thomas,
Justin
Justin,
Can we use the alternative part numbers being referenced by AFS/Dynon with the G3X systems? Seems the new part numbers they are referencing have much higher burst pressure specs. Will the G3X sensor characterizations handle those as well as the TSO'd part numbers you reference above?
Mine are not leaking but if there is extra insurance to be had, I would swap em out as long as I knew the alternative is truly better from a temperature and burst pressure standpoint.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-21-2020, 09:52 AM
Default data point
I talked to Garmin and they are recommending the 75psig sensor (which is apparently TSO'd). Part number they gave me was 011-04202-20.
They said they could not comment on any of the other manufacturers recommendations but that the G3X was pretty lenient on what sensors could be used...
I was not able to find any of the P255-150g-e4a sensors that AFS recommends; I called them to see if they had any and they asked me what EFIS I was using. I told them Garmin and they said they only had a few and would not sell me one because my system is Garmin...saving them for the AFS customers.
I was able to find the Garmin 011-04202-20, though. Be careful, I kept getting contradictory info...for example, if you put that part number in the ACS website, it will give you the 50psig sensor, NOT the 75psig.
There are also the sensors such as the UMA version...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 05-21-2020, 07:36 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Anyone have the actual Kavlico part number. If found this https://store.schnitzracing.com/kavl...iABEgJdTfD_BwE
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 05-21-2020, 09:36 PM
hgerhardt's Avatar
Default Reading comprehension?
Go back and look at post 7 in this thread. That document has Kavlico part numbers. And your link is the old style that's being retired.
