05-17-2020, 10:53 AM
Preventing Rod End Thread Corrosion?
Heres what I pulled out of my rudder yesterday while doing another repair...
Seems to be galvanic corrosion from the reinforcement plate, rudder horn and rudder spar. I pulled the other heim bearings and they had the same thread corrosion but not as bad as the lower bearing.
Im replacing the bearings but would like some thoughts on preventing future occurrences. I'm leaning towards and annual spritz of CorrosionX to weep down the threads.
Tim Holmes
Appleton, WI
ATP, CFI/II/MEI, LSRM
RV-9A N904DC
2019/2020 Dues Paid
05-17-2020, 11:22 AM
Antiseize
I would think a good anti seize would better. One and done?
Also, why is the plate touching this? Is the clearance hole not big enough, or is it off center?
If it is just junk building up in the hole, I again go back to my antiseize to fill up that spot. JMHO YMMV
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
05-17-2020, 11:42 AM
If you are grounded waiting on this part you are welcome to come grab some from my not-yet-flying RV10. Just let me know which part # and I'll confirm I have them handy.
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
05-17-2020, 11:45 AM
Check out Tef Gel, works great especially in salt enviorments.
05-17-2020, 01:02 PM
Mighty fine of you, but ACS-Midwest is back open now after their "COVID cleanse" and I can get them by Tues. I have enough to occupy my time til then.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
05-17-2020, 01:12 PM
I checked the clearance and it was good. I also checked the construction manual and hole is suppose to be drilled to 3/8"...it looks like it was (I'm not the builder).
I think anti-seize sounds like the ticket, and tef gel looks promising...I'll just stay away from jam nut portion of thread for proper torque.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
05-17-2020, 01:13 PM
VAF Moderator / Line Boy
Are you sure that's corrosion Tim? It looks a lot like what I generally see on lower rudder rod end bearings as an accumulation of belly oil and dirt. On almost every RV tail dragger, you're going to get dirt accumulating on whatever oil/lubrication is there.
Just asking because I have never seen corrosion on those things - even when I lived in a salt air environment - but I have seen lots of grime....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-17-2020, 01:18 PM
I'd like to see what it looks like cleaned up - it is hard to see if the threads are corroded / damaged, or just caked with gunk like others have mentioned.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
05-17-2020, 02:12 PM
Paul
I thought that was the case at first but the picture is AFTER I took it to a wire brush then to a wire wheel on the bench grinder. Its definitely corrosion. Anyway at only $16 a piece its worth replacing all of them on a flight control.
Interesting though is the lower rudder fairing didn't have a drain hole in it per plans and water had collected in it. I wonder if the lower bearing being in close proximity to it had anything to do with the corrosion being worse.
BTW...fully enjoyed your webinar a couple weeks ago!
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
05-17-2020, 02:23 PM
I've had good success with this product called Eck.
https://www.vannay.com/
No relationship other than happy customer.
George
