Old 05-16-2020, 10:42 AM
SteveL SteveL is offline
Default Garmin GTN 650 to Garmin 245 audio panel
[IMG][/IMG]
Good afternoon!
Since there are no numbers on the installation diagram I'm assuming that I need to find pin (com 1 audio out Hi) on the GTN 650 to connect with pin 9 (com 1 audio in HI) on my Garmin 245 audio panel. Makes sense to me, what say you?
Thanks!
SteveL
Old 05-16-2020, 11:17 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Garmin GTN 650, P1003
Pin 5 - COM MIC AUDIO IN HI (INPUT)
Pin 7 - 500 Ohm COM AUDIO HI (OUTPUT)
Pin 11 - COM MIC 1 KEY (INPUT)
Pin 18 - 500 Ohm COM AUDIO LO (--)
Pin 20 - MIC AUDIO IN LO (INPUT)
Cheers!
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 05-16-2020, 11:51 AM
Thanks Brian! Back at it.
