09-02-2019, 09:12 AM
David, have you tried some insulation on the metallic parts? Maybe some fiberfrax covered in aluminum foil tape?
Abnormal behavior initially after climb, vs generally normal after some time period in cruise. Kinda suggests something cooled down a bit. The photos don't show proximity to exhaust pipes.
Dan Horton
RV-8 SS
Barrett IO-390
09-02-2019, 09:29 AM
Great Job Team!!
It is great to see collaboration of a common design emerging for builders to use and remove some of the experimental risk of a build while adding durability and reliability to our birds. Congrats to all who contributed!!!
Originally Posted by DanH
Prediction: Near the divider will be much cooler than any lower cowl location when in flight, and not worse when parked hot.
Having lots of temperature data recorded, I will have to agree with Dan. Although the heads are higher it seems the case, barrels are the dominant driver of the under cowl, under plenum temperatures. I don't have the southern absolute temps but the shut downs seem to follow case and oil temps less than the heads, in my data.
Originally Posted by TS Flightlines
.. . . So we set out to test this idea. 2 airshow seasons with members of an well known show team with good results in 3 variations.
WE have a bunch of these flying around the world with no issues. The one part that did need some help was making a securing bracket that would work for that application. Dan Horton did a great job of this. Again, not for everyone, but better than it was. . . .
Tom
Tom, we have heat/temps, internal flow and fluids, fundamental structural of the mounts, and lastly vibration of the cube. Vibration of the small displacement high kind would be the one of concern since it is rigidly attached to the case. It is a fundamental question for anything that gets bolted directly to any engine.
So - was one of the configurations you tested in the field this mount structure? If so that would eliminate that as a potential issue.
There have been many rigidly attached to the lower structure and they seem to be working quite well. The only thing we could do better is measure the vibration of the cube and it's mounts.
Bill
RV-7
Lord Kelvin:
09-02-2019, 09:42 AM
Dan,
I thought about the temperature aspect for the same reason you did while EI was doing their testing. I'll order some insulating material from ACS and report what happens. I really appreciate the brain trust!
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
09-02-2019, 10:43 AM
Bill---this mounting bracket was not tested, as it wasnt even conceived then.
The fitting concept was tested, with excellent results.
Tom
Ridgeland, SC
09-02-2019, 09:31 PM
Originally Posted by scsmith
I violated one of the install guidelines and mounted it in the cockpit, between the boost pump and the mechanical pump. But it has long straight runs of tubing on both the inlet and outlet sides, with a smooth large radius bend in the tube far upstream. No elbows. I find that fuel flow indication when the boost pump is on is erroneous. Common finding, but the lesser of evils in my mind at the time.
I like your install, except for the elbow immediately upon exit of the cube. This turn in the flow so close to the cube may cause an error in the fuel flow calibration. As long as it is consistent, you can calibrate it out by tweaking the K value. If the influence varies at different fuel flows, it is going to be an issue.
Have others installed this way with an elbow right at the outlet?
just posting as an additional data point. I also mounted my red cube on the cockpit side of the firewall. In fact, due to the ECI constant flow fuel injection I have on the IO340, I have two red cubes inside the cockpit. The outflow cube, going to the engine is mounted as Steve mentioned, after the boost pump and before the mechanical pump. The return fuel line has a second cube on the cockpit side of the firewall as the fuel returns to the fuel selector.
Steve, I do have an elbow after the cube as the line exits the cube and goes through the firewall. My fuel flow readings have been exceptionally accurate. I have 9 years and about 650 hours with dead on accurate readings that are within .01-.02 gph when calculating my fuel burn at fill up. The potential problems with heat and vibration in the engine compartment were the underlying reasons I chose this location. It has worked very well for my airplane.
09-10-2019, 01:08 PM
Originally Posted by gfb
This is a great improvement from the last one, thanks for sticking with it, we all benefit from your efforts.
Is Tom or someone making the brackets? Or might you post some dimensions? I have the afp spider bracket which doesn?t look like yours but is likely an easy replacement. Who makes your spider bracket?
I would second the request for some dimensional information on the final bracket.
05-15-2020, 04:24 PM
Red Cube Install
Gotta say after reading as much as I can about the FT-60 installation, I am as conflicted as ever. There is almost as much conflicting information as what is out there with COVID-19?! To summarize:
From the instructions that came with the red cube:
MUST be installed downstream of the last fuel pump. (Their emphasis...)
Best to have Wires Pointing Up, but NOT pointing down.
Fuel line should not drop down after FT-60
Must be suspended between flexible hoses, and hoses must be supported within 6 inches.
From GRT install:
Do NOT mount on engine due to vibration.
Mount away from heat.
Should be mounted on a straight section of fuel line (6" either side), and another source says 5" before and 2" after must be straight.
...and yet, several people seem to have success ignoring these rules? In fact, mine was mounted right above the exhaust (With a heat shield), on a bracket mounted to the case, with wires sideways, and lasted 480 hours.
Thread Sealant Advice (another can of worms?!!):
Don't ever use teflon tape (seems universal!)
Use Fuel Lube....and DON'T EVER use Fuel Lube! (again, seems consistent except one source)
Use Sealube
Use Permatex 2/3 (but fuel acts as a solvent to these sealants?!)
Use Proseal
Use Loctite 567
Just thought a summary might help someone out and keeping them from having to read for two days...This is not advice, as I have no clue...just a summary as to what is out there...
05-15-2020, 06:14 PM
Jeff----I'll bite (not really). To summarize---WE attempted to come up with a fairly universal location for the transducer. Some mounted low and near the servo (fuel controller) required 2 hoses, a short one to the inlet and a longer one to the flow divider. Almost always the short hose created issues in its length, and getting it EXACTLY right. In some cases, we sent the actual hose and hose ends to the client and had him to the actual mockup, including cutting the hose to fit, then we'd do the final assembly and pressure tests. Have any idea what a PITA that is? Thus---the single hose (not single bullet) theory.
We had tested a version of this in the days when we sponsored a well known RV Airshow Team. So we refined it slightly to use at the flow divider, like Chris' install now. It was going to be easier to find the different sump and servo combinations and figure a hose length for that, than doing individual length hoses for installs. This is NOT perfect, as alot of folks on here have stated. BUT, several saw some merit and offered some help. We sought ( me personally for 8 years) to get a location recommendation from EI, but in their defense, it was 'experimental' and was somewhat out of their hands, and they wouldn't or couldn't give a recommendation. I was able to get them at OSH a couple of years ago to state a positive comment about this particular type of install.
So---Steve and I have been working (slowly) on a bracket. Actually 2 different brackets. Slow, well because sometimes life and death gets in the way, and other projects seemed to take center stage. 2 brackets, 1 for the AFP flow divider and bracket, and 1 for the Lycoming 75009 bracket and Bendix/Precision/Avstar flow divider. The AFP was easier---thanks Don!--The Lycoming was much harder. It offsets the divider Aft towards the accessory case which complicates the bracket design. WE had decided early on to make this bracket from bar stock on the CNC Mill, and not angle bent sheet. That would have been easoer, but I dont know how repeatable it would have been without some sort of CNC metal brake. And, we already had the mill's.
So, Solidworks, 3D printer and a few revisions stemming from not using the mockup engine I have but a real live IO360. Little things--like clearing the cylinder flange nuts, little extra radius here and there to where we almost have it where we want it. On both versions. Each will capture the transducer, and will bolt to the case using a aft center bolt that screws into the mounting boss on the case. This will support the transducer and work with the fittings to anchor it.
This has NOT been tested, but is a working theory using Dan's original idea for Chris' bracket.
WE'll see.
Tom
Ridgeland, SC
05-16-2020, 02:06 PM
Another example
Inspired by this thread and with great support from Tom, I moved my red cube to this position too. It has about 6 hours on it so far and is working fine. I used a different approach for the bracket that might be simpler to fabricate. It uses a longer bolt and spacer to bridge the gap between the bracket and the engine case.
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
05-16-2020, 02:57 PM
Larry---ours is a similar idea---but will actually nest against the Lycoming bracket. WE turned the transducer the opposite way-with the wires facing forward. This moves the transducer body inboard towards the case.
Tom
Ridgeland, SC
