TOTALLY AGREE !!!
I could not agree more !!!!! Bill at Up North Aviation is fantastic to work with. He cut my first panel (VFR - Installed) and he just finished up cutting my second panel. The second panel will hold an avionics plate that is designed around the installation of a Garmin GTN650. I also will be changing from fuses to circuit breakers and added a plate to hold the circuit breakers. I went through a few iterations and design changes and Bill was more than happy to incorporate the changes. His fee for designing and cutting is also fantastic.
If you are looking for someone to help design and cut your RV panel, Bill is the guy.
