Old 05-12-2020, 06:31 PM
mcgaughy mcgaughy is offline
Default Smoking Wing Tip Attachment Hinges
I need to decide soon whether to attach my wing tips with traditional screws or hinges. I was told today that the hinges wear with age and get loose / start smoking. Has anyone had this experience on their tips mounted with hinges?
Ellis. RV7a Tip-up.
Old 05-12-2020, 07:14 PM
noelf noelf is offline
No issues here with the hinge attach method, but then I don't fly that much any more. I have two different sets of wing tips and use the hinge method to rapidly change from one set to the other. I have never had any "smoking" issues, not with the rivets and not with the hinge segments.
If you are concerned, what about all the RV's that attach the cowling segments with hinges and pins?
Noel
RV-6A N6NF
tip-up
flying
Old 05-12-2020, 08:44 PM
Richard Connell Richard Connell is offline
Ellis. RV7a Tip-up.
Sounds implausible to me.
10+y on my wingtip hinges. No problem.
It?s an awesome mod. Only downside is marginal weight gain and probably a days work.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 05-13-2020, 07:53 AM
Raymo's Avatar
Raymo Raymo is offline
You can always bond them with Proseal + rivets to avoid the issue but probably not necessary.
Ray
Old 05-13-2020, 07:58 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
+1 for this. I have 700 hours in 10 years on my wingtip hinges and they look as good as they did day one. Would make this mod again in a heartbeat.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 05-13-2020, 08:26 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Just finished mine on my RV-14
They came out great - really not a lot more effort than the screws i did on my 9.
Mike's guidance was very helpful . . .
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 05-13-2020, 10:17 AM
Jetmart Jetmart is offline
Is there a good resource to find out how to install the hinges properly?
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 05-13-2020, 10:33 AM
MS19087's Avatar
Default Search
Do a search . . . bullojm1 did a nice write up.
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 05-13-2020, 10:47 AM
NavyS3BNFO NavyS3BNFO is offline
Here's the link to Mike's great write-up:
http://rvplane.com/pdf/WingtipHinges.pdf
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
Old 05-13-2020, 11:06 AM
jibby212 jibby212 is offline
I just installed my wingtips using the hinge method. I found it difficult to tape the tips in place until I placed a few inflated balloons in the tips which expanded the tips so they fit the wing snuggly. I also ripped a V groove in a 2' long 2X4 and set it over the trailing edge to keep it aligned while fitting and drilling. It made the process pretty easy.
